Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar 5316 error code f7
When power on some time after showing f7 then press start showing display 11. and again turn power on mechine as working fine. expalin me how to solve the fault.
SOURCE: Sharp AR 5316
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
Posted on Dec 03, 2007
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
  • 255 Answers
SOURCE: ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Posted on Nov 24, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Sharp Photo Copier AR 5316
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Posted on Jul 31, 2010
Testimonial: "than u sir every time i had problem u are helping me sir thank you so much sir"
  • 452 Answers
SOURCE: my sharp AR-5316 is displaying
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Posted on Oct 15, 2010
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Jan 07, 2015 | Office Equipment & Supplies
Error h4 sharp ar-5316 can you help me ?
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
In my office we have a SHARP AR 5127 copier. i have replaced the cartridge and it's worked one month and after showing the error call for service U2-40. I want best solution. Plz. give me soluti
u2-40 is communication problem in mainboard,try to replace the toner cartridge. or reset by programming. here the programme...on the mechine then # interrupt 0 interrupt. if mechine go sleepmode pls press 14 and start.
Feb 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
L6 sub 10
Hello sir; I'm not sure the error code can be reset or not but we can give it a try, the easiest way just turn power on and off if don't work follow following steps;
1, press "#", "interupt" "c" "interupt"
2, enter 14 then press start.
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Remove error in AR-5316
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316
there might be some dirt on thermistor above the heater upper roller pls check and clean the fuser unit then use simulation 14 to reset the machine enter simulation by presssing #,interrupt,c,interrupt in sequence display is then off, then no. 14 then start key h2 disappears ok
Sep 04, 2007 | Sharp AR-5316 Advanced Digital Imager...
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
