Nintendo Wii Console Logo
Posted on Jan 20, 2009
Drop wii disc stuck
Dropped wii disc stuck how do i open it to et disc out lights up no display on screen
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Feb 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
4602
Points
19
Your disc is stuck in Wii Console, It needs to eject manually.. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Wii disk will not stay in the console
Has anything been jammed inside the Nintendo Wii to cause this?
Has the Nintendo Wii been dropped?
There are usually 2 causes for this.
The Nintendo Wii disc drive could be damaged and/or something is jammed inside the drive causing the discs to automatically eject.
Also, your firmware could have malfunctioned, causing the drive not to work.
If you have experiencing opening the Nintendo Wii up, I would recommend you do so and look to see if anything is stuck inside.
if you're not comfortable doing so, I would recommend for you to send this system in for repair.
Wii won't take or eject discs
look for a snapped or crocked disc reader near the lense
I drop my nintendo wii console, and later I tried to eject the disc,but it didn't work. I could only play the game that's inside the wii.
I've seen many people with this same problem.
I think if you drop the Wii, the disc ejecter breaks or something. Then you can't eject the disc or vice versa because the ejecter is broken. Call Nintendo Customer Service (1-800-255-3700 in the USA or Canada) and try to get it repaired.
1helpful
Disc won't eject
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
The wii dropped and now it says it can't read disc and it won't spit it out
Contact nintendo and let them know that your getting a disc read error, and that the system was dropped. Also let them know that there is a disc inside, they will talk to you about physical damage, which is not covered under their warranty. So a repair from them, your looking @ about 57bucks
3helpful
3answers
My wii spits my disc out after i put it in system
I've found that this is usually caused by a problem with the small plastic gears that operate the loading mechanism. Sometimes they break, need to be realigned, or get stuck.
If one or more of them have a problem then the loading mechanism never allows the disc to drop onto the motor to spin. Then the Wii realizes that the disc did not load properly and kicks it back out.
But the only way to see is to take the Wii's cover off.
2answers
My Wii Reads Disk, but WONT EJECT IT
If it is still under warranty use the link provided
Nintendo Support
Fill out their form and be very descriptive when asked and they will repair it.
Alternatively you may choose to open the case and examine the damage - This is unadvisable as you warranty will be void and you could further damage the console
1helpful
3answers
2helpful
4answers
Disc stuck in ninteno wii console
the eject button must of gotten stuck into the wii.don't take your wii apart.call the nintendo customor support number :1-800-255-3700.they will tell you the problem and before you know it.it will be fixed
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
