Question about Acer AS5252-V476 15.6-Inch Laptop (Mesh Black) PC Notebook
Acer aspire 5252 v662 recovery how to factory settings
SOURCE: acer aspire 4315 recovery cd file...
all you need to do is go to Acer Empowering Technology (the e on the left side of keyboard) and then go to Acer Recovery Management
Posted on Jan 29, 2009
zohail
  • 1223 Answers
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Posted on Apr 13, 2009
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
  • 65 Answers
SOURCE: Acer Aspire 5315 No Recovery Disk - Restart
yes you can use the recovery partition which should be built into the hard drive. press f2 on the bios screen and follow the on board instructions. this will return the laptop to its original factory state. Keep in mind that this is a destructive reinstall of windows and you will lose all data and programs.
make sure you do a recovery and NOT a system restore to earlier date.
hope this helps.
Posted on Dec 10, 2009
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
Restore to factory settings
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen.
The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options.
Choose "Factory Restore" to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
Jun 13, 2013 | Acer Aspire One Netbook 8.9" Notebook
Aspire one needs rebooting no disk
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 14, 2013 | Acer Aspire One PC Notebook
Acer Aspire 8930G 0xd0000017 recovery error
Jan 30, 2013 | Computers & Internet
I dont know how to restore my acer with linux back to factory settings
Jan 20, 2013 | Acer Aspire One Netbook 8.9" Notebook
I DONT KNOW HOW TO RESTORE MY ACER BACK TO FACTORY SETTINGS
Jan 20, 2013 | Acer Aspire One PC Notebook
My ascer 5352 want restore
or
Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management.
If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD.
Click the Restore button and select the option that reads "Restore system to factory defaults".
Wait for the computer to finish the restore process and reboot.
Restoring for the Boot Screen
If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time.
When the eRecovery menu appears, choose "restore system to factory defaults".
Wait for the recovery process to complete and the computer to restart
hope this helps
Oct 23, 2012 | Acer Aspire 5252 5253 5336 5552 5736 5736g...
Factory restore acer 5252
hello how do i restore my acer aspire 5252-v305 laptop to factory settings
Aug 13, 2011 | Acer AS5252-V476 15.6-Inch Laptop (Mesh...
HOW TO RESTORE ACER 5252-V476 BACK TO FACTORY SETTINGS
To restore your Acer to factory settings read the information from this link.
Mar 28, 2011 | Acer AS5252-V476 15.6-Inch Laptop (Mesh...
Need Acer Aspire 5720G Recovery disk (CD)
visit the web site has> (http://www.acer.com)> to get what you need to recovery
Jul 22, 2009 | Acer Aspire 5720 Notebook
Acer Aspire 5500
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Nov 06, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer AS5252-V476 15.6-Inch Laptop (Mesh Black) PC Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
