Question about Elements Of Design Plumbing
Gap between basket & body of basket strainer
While designing basket strainer, what shall be the optimum gap between the strainer body & basket?
Noticed in several case that this gap is maintained at 10-12 mm.
Is it a standard practise or vary with size?
Please advise
  • 49 Answers
Can you clarify that, i am not sure what part of a basket strainer dimension you are refering to. the dimensions of a basket strainer are related to the standards of the fixtures they are installed on. It has to be designed to work on different thickness of materials; thick materials such as cast iron or marble and thin materials like stainless steal and pressed steal. I have experiensed some strainers that do not meet this and are not deep enough to fit thick materials o r do not tighten enough to handle then materials.
Posted on Jan 23, 2009
How can I fix my pool cleaner from flipping upside down during the cleaning process?
Remove weights, Thoroughly clean cleaner, backwash filter system to get optimum suction. Check filter system for optimal suction..., ie. leaks, excess debris, clogged baskets, strainers, etc..
Apr 11, 2016 | Pool & Spa
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
I have a pegasus sink and I'm having a hard time getting the drain not to leak. The base of sink if thicker in the front than the back so when we tighten the drain it will only tighten so much in the back...
You need to take it off copletly and clean it then take 100% clear silicon put it down on the sink base and on th e bottem lipe of the basket strainer tighten down till silicon sqeezes out top of sink wipe with paper towel and wate 24 hours befor use.
Jan 21, 2011 | Pegasus Technologies Pegasus Kitchen Sink...
Plug gaps
Manufacturer Spark Plug Gap A spark plug part number might fit hundreds of engines and although the factory will typically set a gap to a pre-selected setting this gap may not be optimum for your particular engine and may not take into account modifications that you may have made to the engine. Spark Plug Gap – Bigger is Better The larger the spark kernel that is generated by a spark jumping the electrode gap, the more likely and complete the fuel burn will be, and the smoother the engine will run. That is, the larger the spark gap that’s exposed to the air/fuel mixture, the easier it is to initiate combustion. This translates directly into improved throttle response. So, the larger the plug gap you can run (without misfires) the better. Unfortunately, the greater the plug gap, the higher the voltage requirement to jump the gap. The difficulty lies in that, any added gap creates more strain on the other ignition parts. Coils, for example, may not have enough stored energy to cross the gap, creating a misfire. Old plug wire insulation can break down at the higher voltages required to fire a larger gap. The stock Ducati coils are good enough to fire a 0.044-inch plug gap. Any gap larger than this will likely result in more misfires (there’s always a few) and subsequent power loss. The correct new plug gap is specified at about 0.024-inch (0.6mm). But, remember, as a plug wears, the gap opens up further. If you use conventional sparkplugs, start with the recommended gap and try opening the gap up in 0.002-inch increments. You should note a progressively smoother throttle response if not more power. When the bike begins to lose power, go back 0.001 - 0.002 inch and this will be your optimum gap. I don't know offhand what the DCPR8E plug comes pre-gapped at but as a good rule-of-thumb, if you go more than 0.008 inch over the out-of-the-box gap you won’t maintain parallel surfaces between ground and the center electrodes. So if you reach that point, change to a plug that starts at a larger gap. The NGK dash 9 series starts at a 0.9mm (0.035-inch) gap, and is used for that reason. If you run iridium or platinum electrode plugs, start with the 0.035-inch gap that they are shipped with. Don't run them at smaller gaps or you'll loose throttle response. If you have a older bike, you may arc over the plug wires before you can reach the optimum plug gap. If the spark plug wires have inadequate insulation, the wire cannot maintain a high enough voltage across the insulation and will arc to ground before firing the plug gap. The factory spark plug leads are stranded wire covered with an EPDM jacket and although the wire itself will last a long time, the jacket will start to break down after a couple of years which is why most good aftermarket wire is insulated with silicone rubber. If this is the case, replace the stock spark plug wires with a set of Magnecor or similar quality wires. This will allow running a larger plug gap without a concern for insulating the higher voltage needed to jump the gap. Ducati 916 Magnecor #2549 wires, for example, run $67. Ignition Amplifiers Running a larger gap is the main benefit of installing an ignition amplifier, such as the one sold by Evoluzione for Ducati's. The Evoluzione ignition amplifier increases the primary voltage to the stock Ducati coil from the existing battery voltage to either 16 volt or 18 volt (user selectable). A higher primary voltage means you get a higher secondary voltage applied to the wires and plugs. The higher the secondary voltage - the larger gap it will jump across. Evoluzione recommends that for best throttle response, you run a 0.060 inch plug gap. One reservation that I have about ignition amplifiers as a group is that they could possibly cause overheating and eventual failure of the stock coils or wires. This reliability consideration has to be balanced against improved performance. An independent test by Road Racing World magazine on a GSXR 1000 saw only about a 0.2 HP improvement, but throttle response is the major benefit.,,,
Nov 10, 2008 | 2000 Ducati MH900e
Plug gaps
Nov 10, 2008 | 1986 Ducati 350 F3
Plug gaps
Nov 10, 2008 | 2008 Buell XB12XT
Plug gaps
Nov 10, 2008 | 1999 Bimota SB8R
Plug gaps
Nov 10, 2008 | 2005 Benelli Velvet 125
Plug gaps
Nov 10, 2008 | 1972 Aermacchi Sprint 350
Basket Strainer Specs Question
1\ Amount of free open area is the ratio of the open area through the strainer basket to the cross sectional area of the pipe. A good basket strainer should have a ratio of 4 to 1. 2\ Ease of basket removal is important because baskets may require frequent cleaning or replacing due to buildup. 3\ Compactness of the design saves you valuable space. A small strainer is less bulky and easier to handle. 4\ Availability of basket perforation sizes gives the strainers the flexibility to cope with a wide range of particle sizes.
Aug 27, 2008 | Moen 22174 Stainless Steel 2in. Basket...
Plumbing Logo
167 people viewed this question
Top Elements Of Design Plumbing Experts
Paul Carew
Tom Chichester
Are you an Elements Of Design Plumbing Expert? Answer questions, earn points and help others
