AC is not working for the past 20 days, we have complaint to your office, the serivce person took our ac unit to there workshop and they brought to our house' 19.1.09 still now is not working huge amount ice is formed in the unit , we are not happy with your service team at chennai. my tel 091 44 25515209 YOU LOG IN THIS TEL NUMBER You will get all details our complaint.
  • 1,543 Answers
We are not associated with any manufacturer. We only offer free service assistance. Ice formation indicates insufficient air flow. Clean or replace your air filter. Make sure you do not have unit set to draw in outside air while operating. This should be a Fix-Ya for your air conditioner.
Posted on Jan 20, 2009
I just had the AC Adapter connector replaced on my motherboard. I cannot use the laptop without the AC plug in, presumably because the battery is dead. When I plug in the AC adaptor plug the Amber
The company that repaired your laptop did not do a proper job. They should not charge you for further work. I suggest you take your complaint to your government consumer complaint office to get this problem resolved.
Aug 04, 2012 | Dell Computers & Internet
AC doesn't blow cold air.
I'm sorry you have had such bad experiences with the shops.
I would have stopped at the second one and forced them to fix it at their cost.
I doubt you will be able to find the problem yourself, but I understand your hesitation to go back to another mechanic.
I will be happy to try to walk you thru the diagnostic process but it may take a few days.
First, do you know if the system is full of freon ?
If it is full, do you know if the compressor is running when the ac is switched on ?
The first shop should have discovered the blown fuse once they charged the system unless it took a day or two for the fuse to blow. The second shop that put the compressor on should have found the faulty fan, and the leaking hose if it is in fact leaking.
So should have the third shop.
If the compressor was faulty, and the system had been empty for a time, the hose could have started leaking once the system was being used. The pressure on the high side is over 200psi when the compressor is running.
Let me know where you want to start with the diagnosis after you answer my questions.
Jul 28, 2012 | Cars & Trucks
I have purchased one Samsung Split 1.5 ton AC from Vijay Sales ? Baner Road branch on 19th Sept 2010 by paying cash payment. The same ac was delivered to me on 21st Sept 2010. The Samsung Authorised...
You have a LEAK from installation that must be found & repaired before any more GAS is added to the system.Then it will normaly need a little gas every 3 years.
Sep 29, 2010 | Samsung Heating & Cooling
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
A/C just quit working. No cold air.
there are few problem with the A/C cooling system better check for A/C unit fuse weather it is blown or in good condition, check for the proper working of A/C condencer unit fan motor assembly for proper working, check for weather their is no lick of gas any where in the entire A/C unit complete system or more problem better consult or take the vehicle to nearest Hyundai authorised workshop or better take it to a well knon or experiencied person who had done this sort of problematic work.
Jul 22, 2009 | 2003 Hyundai Santa Fe
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
A complaint for repairing of AC.
Not all retailers maintain a service support staff. They sell at a cheaper price for this reason. You pay a higher amount of money for an item when the business has a service support staff and you get service when you need it. You stated that your system is a split system which requires connections of piping and electrical between the outside unit and the cooling end inside. Whom did the installation?
May 16, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
326 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
