Question about LG LW20-EV Notebook
Can't get my LG Notebook default screen resolution back
I attched a Barco to my LG wide screen laptop. When I plugged it out, it changed my screen resolution. My friend told mt to get into 'settings' but noneog the resolutions offered on that bar is the one I had before. Now the desktop look funny - small Icons (every coulm ends in the middle of the screen) and the wallpaper is smaller than the screen and centered.
What shell I do??
  • Anonymous May 05, 2009
    hi my screen is too big
  • S_Nandha May 11, 2010
    Which operating system do you use?
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
Can't get my Dell Precision M50 Laptop video to fill the screen at 1024 768 resolution. Video will only fill the screen when I set resolution to 1600 1200. Is there something wrong with my video card?
1024x768 is a native wide-screen resolution. more than likely your video card is fine and your notebook monitor does not support that format without shrinking the top and bottom which defeats the purpose of filling the whole screen. plug the kappy into an external widescreen monitor or TV and it will work at 1024x768.
Regards
Jun 06, 2010 | Dell Precision M50 Notebook
My Father's Toshiba Satellite Pro A120 laptop is
about the icons moving, it is because of the resolution... when you plug in your laptop to a wide or bigger screen it changes or adjust the resolution so it would fit in the screen...
Nov 22, 2009 | Toshiba Satellite P300-ST3712 Notebook
Display defaults
This is normal as the TV can only display at a lower resolution unless you connect it to a high definition TV. Just change the display resolution back to 1024x768 when you are using the laptop's LCD screen.
Apr 11, 2009 | Compaq Presario 700 470024-192 Notebook
How can i change resolution for games in wide screen laptop?
It depends on the game, for many games you can change the resolution of the game by, going into the game settings.
Try and let me know .. Kevin
Mar 30, 2009 | Toshiba Computers & Internet
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
I need a driver for gateway 17 in. wide screen monitor FPD1775W
You might want to consider a default settings reset. To refresh or reset the monitor back to default settings, unplug the monitor's power cord, and then press the the power button for five (5) seconds to drain any residual power. Plug in and then turn on the monitor. The default settings load.
Additional information about your monitor is available on the Gateway support website.
Nov 19, 2008 | Gateway FPD1775W Monitor
Shape of drawings on screen
dear ,
toshiba a100 laptop is having a 15.4" wide screen , it seems that u are selecting a resolution according to 4:3 ratio screen , u have to select a resolution suitable for a wide screen { 16:10} for example u can try 1366x768.
mail me ur response @ vishwas_4u@rediffmail.com
Apr 30, 2008 | Toshiba Satellite A100-S8111TD Notebook
LG LW20-EV Notebook Logo
222 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
