Question about Abit AS8 Motherboard
NO Sound - 865PE Neo2-PFS Platinum Edition
I'm getting no sound (except for typical low volume "white noise") from the external speakers attached to a new, OEM MSI 865PE Neo2-PFS Platinum Edition motherboard. Here's are my "vitals". MSI 865PE Neo2-PFS Platinum Edition w/ onboard Realtek AC'97 CODEC (ALC655 chip) onbord RealtekĀ® 8110S Ethernet "NIC" AMI Bios V 3.9 Intel P4 @ 3.0 ghz Kingston HyperX KHX3500/256 (one stick, @ 2-3-3-7-8) Asus V7700 GForce2 GTS Deluxe w/ 16MB w/ v5.6.7.3 drivers IBM Deskstar 120GXP 80GB 7200PRM IDE (port 0) Aopen AOpen CD956E CD-ROM (port 1) Sony CRX195-E1 CD-RW (port 1) Unknown Brand Floppy Disk Drive CTX PL9 19" Monitor Enermax EG365P-VE (FMA) Power Supply 32A on +3.3V line, 32A on +5V Line and 1A on +12V line 185W on +3.3/+5 Powered Altec-Lansing Speakers (2) WinXP Home SP2 (no luck w/ "original" WinXP Home either) After several failed attempts - and numerous visits to this forum (thanks to all) - I devised and employed the following "clean install" procedure. Jumpered pins 5-6 and 9-10 pins on the JAUD1 front panel audio connector Powered up, entered BIOS Setup and disabled onboard LAN and audio Boot w/ WinXP Home Edition (pre-SP1) in CD-ROM Drive Installed WinXP Home Edition (clean install w/ full format of target partition) Installed WinXP SP2 Upgrade (which was uneventful) Installed Intel's INF chipset drivers Enabled onboard "NIC" in BIOS Setup & rebooted Installed LAN Drivers (the "NIC" works well) Rebooted Installed DirectX 9.0c (the sound chip requires V8.0 of better) Enabled audio chip in BIOS Setup & rebooted Installed the audio drivers (5.10.0.5620) as described here ... Guide to Realtek sound on NF2 boards (by backwoodz) Rebooted ALL of the drivers were acquired from MSI's website. Other facts. Other than the audio, the rig is stable and fully functional DOT and MAT are turned off Windows Device Manager says that ... ALL installed devices (incl. The audio chip) are working. The audio chip has IRQ17 all to itself. The device's audio properties says "Use this device (enable)". The Control Panel applet says that the Realtek audio chip is the default for sound playback and recording. All volume controls have been set to full, unmuted volume. Soundman was configured for simple 2-speaker stereo mode (which is what I have). Soundman was subsequently reconfigured to employ all other (11) possible settings (but not, of course, at the same time) ALL (3) of the various power supply calculators I've tried suggest that mine is more than adequate I have no "extra" stand-offs and no stray conductors under the motherboard. I don't have an I/O sheild or the D-Bracket Yet, I'm not getting ANY sound from Windows itself (e.g. At startup and shutdown), Windows Media Player 9, Soundman or the CD-ROM. But, the speakers work when they're plugged into the headphone jack of the CD-ROM drive. I've tried all four hardware acceleration settings, am not overclocking (at least not yet), And, yes, after all that, I downloaded the new (5.10.0.5720) drivers from Realtek's web site and installed them. Nada. At this point, I'm inclined to believe that the Realtek audio chip is defective and that I should buy a sound card. But, if you've got an idea, I'm listening. Thanks in advance!
Please refer to manual.
If you don’t want to connect to the front audio header, pins 5 & 6, 9 & 10 have to be jumpered in order to have signal output directed to the rear audio ports. Otherwise, the Line-Out connector on the back panel will not function.
Posted on Dec 08, 2008
I need audio driver hy xdl01 plz
Posted on Oct 25, 2008
You need to install the correct version of the sound drivers from the MSI website under your motherboard type. Third party or from Realtek sound drivers won't make you sound chip works. If after installing sound drivers from MSI website still don't work then your on board sound chip colud be defective.
Posted on Jun 29, 2007
SOURCE:
Instal driver but sound not coming
Hello download the right driver here:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=All
Please select your windows and unzip the file when downloaded.
You also need the chipset driver.
Here is only drivers for win xp so if you are running windows 7 or vista you have to buy a soundcard because the driver is not supportet for a new windows system.
The green outlet is for the speakers and see that the volumen isen`t
turned down low or muted.
Good luck
Dec 03, 2012 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Perescott 533 driver
Hello the drivers can be downloaded here:
Please select your windows system.
If i am wrong by the mainboard model, enter the ms xxxx number here:
http://www.msi.com/service/download/
The ms number is located here:
Good luck
Oct 05, 2012 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
How to instal the vga for prescott s33 mother board
Hi, here is the download site for your mainboard:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=XP%2032
Try also windows update.
And try to look for the screencard driver elsewhere.
http://support.amd.com/us/gpudownload/Pages/index.aspx
http://www.nvidia.com/Download/index.aspx?lang=en-us
You can find the screencards name in the device settings.
Hope this will help you.
Aug 15, 2011 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
I can't use my USB port
Hi, try to update your drivers from here:
Remember to select the windows system you are useing.
The drriver needs to be unziped before installation.
Try also to run windows update or microsoft update.
The usb driver is in one of the service packs.
Apr 12, 2011 | MSI 865PE Neo3-F Intel 865PE LGA775 DDR...
What is the max dual channel ram i can put iin my msi 865pe neo2 motherboard.
Hi merlin_65,
Regardin your question:
• Supports four unbuffered DIMM of 2.5V DDR DRAM.
• Supports up to 4GB memory size without ECC.
• Supports Dual channel DDR266/333/400/433/466/500/533 MHz and up. (DDR433/466/500/533 are overclocking spec).
Hope this helps.
Feb 22, 2011 | MSI : 865PE Neo2 (Platinum Edition)...
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
Abit AS8 Motherboard Logo
765 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Bart Fonteyne
Dapid Candra
Dapid Candra
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
