Question about Canon imagePROGRAF W7200 InkJet Printer
W7200 plotter - the ink tubes are empty
My W7200 plotter printhead has no enough ink. The tubes are empty, or with a few ink in. The printhead is writting only with the remainted ink now. The ink tanks are ok, and I done A and B cleaning printhead.
I find a small cylindrical part with a spring attached, cought in the place where the printhead park. This steel piece has 5 mm diameter and has two 2 mm diameter places probably for attaching two springs, but I find only one spring. I don't know where this piece come from, but I think it belong the plotter.
Please help me to solve the problem before clogging the printhead.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Well, it is not good situation for you because you got a mechanical damage of printhead support. Besides a cylindrical part whith one spring, try to find second spring inside plotter case. And then you'd better call service to change broken support detail (plastic lever in carriage assy). BTW it commonly encountered problem for W7200.
Posted on Feb 20, 2009
Download driver printer canon mp 150
Posted on Jan 20, 2009
Hi my plotter always print a blue color on all pages.for each kind i print i have it has no differences.does any one knows about my problem? my plotter model is Canon W7200 thanks best regards
Try printing the Nozzle Check pattern. Check if colors are printed correctly. If not, try Printhead Cleaning A first then check again the Nozzle Pattern. If there's a small changes to the pattern, try Printhead Cleaning B. If problem persist, try changing the Printhead.
Oct 09, 2014 | Canon imagePROGRAF W7200 InkJet Printer
Canon w7200
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 16, 2013 | Canon imagePROGRAF W7200 InkJet Printer
No 64 bit driver for Canon W7200
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-
Dec 21, 2010 | Canon imagePROGRAF W7200 InkJet Printer
ERRORE E0200D plotter canon W7200
Hi. I have a problem printing the bar code symbol is similar to
Oct 07, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Plotter canon w7200
HO il medesimo problema...come l'avete risolto?
Feb 10, 2009 | Canon imagePROGRAF W7200 InkJet Printer
Take it out and clean all contacts, worth a try as they cost £500 from canon. An engineer told me they usually only last about a year and after problems with the cutter failing and colour problems in drawings we got a new one which fixed the problems. Third new printhead in 4 years, canon should be ashamed.
Oct 07, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Problem in w7200
Hi - I had a different problem involving the carriage, but the solution may help you. There is (or should be) a pin on the carriage, visible on the right side when you lift the plastic pieces that hold in the printhead. This pin is about 2 in long and varies in diameter from about 1/8 inch diameter to 3/16 inch diameter. If this pin is not there, which in my case it had fallen down into the ink purge unit, the black will be shadowed by magenta. I don't know how to fix that part, but if the pin is gone you may soon have a bigger problem, which is the pin binds in the gears of the ink purge system and the printer won't do anything after that. Check for the pin, and if its gone and you live in an area where someone can service your machine call them up! In my case i was able to dig the pin out myself and the printer works again, but there is a slight overshadow of magenta.
Nov 21, 2007 | Canon imagePROGRAF W7200 InkJet Printer
Canon imagePROGRAF W7200 InkJet Printer Logo
725 people viewed this question
old marine
old marine
