Question about Roper Dryers
A small glove fell down roper driers lint trap is it a fire hazard and if so how do i get it out
reg501
  • 413 Answers
SOURCE: lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
barkencoa
  • 3463 Answers
SOURCE: Sponge fell into lint trap.
Surely you should be able to remove lint trap, or you would not be able to clean it!!!!.
Otherwise try a piece of wire with a hook on the end , and retrieve it that way.
Posted on Dec 15, 2008
  • 91 Answers
SOURCE: Lint fell off trap and down into dryer chute.
for the most if you want to clean it it will take you a while, depending on your model, disconect the unit from the power outlet first,from the back panel remove about 6- to 8 screws an then you will see the inside back panel expose to be vacumm, you'll see the back panel of the shoot that runs behind the dryer, take the i think 4-5 screws an vacumm it, i dont think is going to hurt your machine if a little fell in there, a quick way is try to remove the exhaust tube off the back an insert the vacumm cleaner, to clean the tube going out of the house you can use a strong shopvac, to **** it in or a leaf blower to push it out ...........good luck!
Posted on May 28, 2009
dawson57
  • 25 Answers
SOURCE: Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Posted on Jul 13, 2009
  • 491 Answers
SOURCE: object fell in lint trap
GO TO A HARDWARE STORE AND ASK FOR A TELESCOPEC MAGNET USE THIS REMOVE CLIPPER FROM TRAP .
Posted on Nov 30, 2009
DRYER TAKES 2 CYCLES TO DRY. WHAT CAN BE THE PROBLEM
Check to make sure lint hasn't built up in the area of the lint trap and on the exhaust where it leaves the room. Improper air flow will cause the drier to over heat and shut down the elements to prevent a fire. Once the elemnts are cool then they start again until they reach that temp. again then they shut off. So check for lint buildup before anything else
Hope this helped
Dave
Mar 03, 2010 | Dryers
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Whirlpool GEW9250 Electric Dryer
Object fell in lint trap
Nov 30, 2009 | Dryers
WE HAVE A GAS DRYER ROPER RGX4634KQ2, HOW DO YOU CHANGE THE IGNITER?
1st unplug. Take off the back panel. Yeah that means you have to pull it out and disconnect everything. While you are at it clean out all of the built-up lint. That becomes a fire hazard. Good luck
Oct 17, 2009 | Roper RGX4634KQ Gas Dryer
Jul 13, 2009 | Whirlpool Dryers
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Roper (REX5634PQO) dryer will not start
This fuse mounts right beside the filter housing. Maybe you unpluge a wire while fiddling with the housing. If this fuse blows then the dryer will not run.8ab116a.jpg
Nov 23, 2008 | Roper REX4634KQ Electric Dryer
Small plastic toy down lint trap
is the lint filter on the top of unit??? if so you ll need to disconnect power remove the 2 phillips head screws under the lint trap holding it to the main lid. then after removing about 10 1/4in screws from back panel you ll see a metal sleeve running down the back of the unit( the lint filter actually slides in to it) ending in a circular shape below. remove perhaps 4 more screws holding that panel on and youll gain acess to retrive whatever has fallen down there. easy enough to do yourdself no need to call in a professional
Oct 23, 2008 | Dryers
Dryers Logo
15 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
