Question about Epson Stylus C60 InkJet Printer
MY Epson Stylus C60 wont print
I get a message "error writing to LPT1". Then no print.The green light is on and the red is on, but the third light is off-I do have another printer installed HP500.
  • gaz skinner Jun 29, 2007
    Sorry I forgot to say Windows 98!
    I should have added it is Wibdows 98!
    President:
  • 2,961 Answers
This means that your printer is trying to print from the wrong serial port connection, as your printer should be connected via a USB cable. Go to start>control panel>printers and faxes. Double click the printer and faxes icon and your Epson printer icon should be there and set as default with a tick next to it; right click on the icon>properties and then at the top of the next window, click on the tab that says ports and a list of ports will be there and the one that should be ticked should be USB001, and not LPT1 as it will be show, press ok and close windows and restart the pc.
Posted on Jun 29, 2007
SOURCE:
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
I have a blinking red and green light on my c60 epson printer that stays blinking. It wont print. What can I do?
you need to reset wast pad counter by using adjustment program. you can download a program "SSC service uitilities"
Dec 27, 2009 | Epson Stylus C60 InkJet Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
May 25, 2009 | Epson Stylus C43SX InkJet Printer
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
Apr 07, 2009 | Epson Stylus C60 InkJet Printer
My troublesome printer
New ink comes with a strip attached at the ink hole and sensor area, makes sure u ermaove them also try to clean the catridge contacts in the printer
Mar 06, 2008 | Epson Stylus C60 InkJet Printer
Epsom stylus c60
For the record, problem solved!
Mar 05, 2008 | Epson Stylus C60 InkJet Printer
Epson stylus c60
hmmm..is the cable from the printer to computer happy? unplug it, and see if it shows on the computer screen, when you plug it back in.
Epson Stylus C60 InkJet Printer still not printing
what is the connection? USB or parallel ? Try1. Disconnect the printer. Unistall the software and driver. Restart the computer. Now re installed and follow precisely the commands. Come off line Disable A/V software Do not connect printer untill prompted. Try2 Go to printers and faxes Click on install printer When asked CD or select from List - take select ftom list. Select the Make. Select the model. Make it the default printer. Try 3. Go to www.fixyourownprinter.com
Jun 29, 2007 | Epson Stylus C60 InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
