Question about Candy Dishwashers
Error e4 is showing on a candy CDI4545-80
Dishwasher leaked before this happened
SOURCE: E4 error on new conia dishwasher
I have a Maytag MJD3000AAW dishwasher and it was showing E4 during a cycle. On checking the pressure tube from the outlet of the dishwasher to the nozzle on the u tube under the sink, I fould that the dishwasher was not draining properly as a kink have developed in the tube where it curved back to the nozzle. I slid the pressure tube into a long elbow which stopped the tube from pinching. Problem solved.
Posted on Nov 02, 2008
whytfang
  • 170 Answers
SOURCE: E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Posted on May 19, 2009
SOURCE: Problem with Candy CDI45, Error E4
The instruction manual defines E4 as "overfilled", a possible reason being too much inlet water. What helped with our machine - removed all dishes inside, then let the machine's pump run briefly to make sure as much water was drained from the system as possible. I then unplugged the device, placed a large towel on the floor around its base, and tilted the machine front-ward, until all water had run out. Lifted the machine back upright, plugged it in, switched on - and voilà! it's working as I speak.
Posted on Nov 06, 2009
SOURCE: machine not working showing E4 fault
something is stuck in the filter (big olive, valve from baby bottle...) so the water can't get out. Clean filter, then make sure all water is out of the machine (we sucked it out ourselves with a tube and a bucket, ieuw..). Then wait a couple of days: the machine/wires/etc. needs to get dry before you can use it again! Try to turn it on after two or three days. Do not call an expert before you've tried this, it will save you a lot of money... (wish I'd done it...)
Posted on May 27, 2010
SOURCE: Candy CDI 45 E4 code
I have E1 code on Candy dishwasher CDI 45
Posted on Sep 29, 2010
Our dishwasher has the message e4 on display
You don't say which dishwasher you have..
But e4 is normally antiflood... At the bottom of most dishwasher is a plastic tray that catches leaks and condensation, If water builds up in it the float switch trips.
Depending upon your abilities, it is possible to get the water out using a sponge or cloth... if you are successful and it happens again in a short space of time you might have a leak which will require further investigation.
Apr 16, 2017 | Dishwashers
My candy dishwasher is CDI505-S,and the problem is that in the coutdown button appeared E4 and the machine doesn'run,please what can I do......
It is most likely that there is flooding in the dishwasher due to water leakage.
This information thread from another model might be helpful in solving the problems.
Good Luck.
Jun 01, 2011 | Candy Dishwashers
Error Code E4 on my Candy CDI 45 Dishwasher
get you get it fixed? I have the same error
Oct 12, 2010 | Dishwashers
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
I have a Candy dishwasher. Door is open switch on sounds like something (possibly pump) is running and error E4 shown on diaplay. Any ideas please?
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
Jul 20, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
BDW45.1 Baumatic Dishwasher E4 alarm
Check and clean the filters on the inlet water line (both sides). Good luck!
Sep 03, 2007 | Baumatic 18 in. BHD45 Slim-Line Built-in...
Dishwashers Logo
127 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
