Question about Samsung Washing Machines
I have a Samsung top load model wa80u7 and it is full of water with clothes and it display 1E .it would not start again.help please thanks
I switched it off and start again but every time it didplays 1E
aborcass
  • 2651 Answers
SOURCE: won't spin out water
sounds liek you have a bad clutch assy, not engaging fully, tip the machine back and give a look around teh inner perimeter of the cabinet, do you see brownish oily streaks dripping down, perhaps a pool of oil under hte unit??? if so you need a new transmission(5 year warr) and clutch assy
Posted on Mar 23, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
  • 43 Answers
SOURCE: My Kenmore Series 80 washer model 23832100 spins slowly
It probably is your clutch. You will need to remove transmission to repair this.
Posted on May 12, 2009
SOURCE: Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
Posted on Jun 10, 2009
  • 6277 Answers
SOURCE: I have a Samsung VRT front load washer, it was
First is to empty the water out. This can be done by following my (complete) general guidance notes below for checking the drain motor lint tray/filter and the motor.
'nf' means NO FEED and what happened afterward indicates that the water feed control valve is malfunctioning, initially not opening for water to be fed but then sticking open.
So follow these notes, particularly those in capital letters, to find how to empty the washer, and to check the state of the filter which is needed on a regular basis anyway ;-0)
Next will be a call to a service engineer to sort out the suspect valve.Sorry ;-0(
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 01, 2011
What is error code SC on Samsung washer?
If your washing machine malfunctions, you may see an information code on the display.
Please see below for possible solutions for each information code. If you have tried all of these and are still experiencing problems, you may need to contact the Samsung Service Centre to arrange an engineer visit.
CODE: 1E, E7, 1C (Water level sensor)
Action:
Switch off the appliance at the mains then wait 30 seconds. Switch appliance back on again and start a new program. If the information code remains, contact the Samsung Service Centre.
CODE: 3E, 3E1, 3E2, 3E3, 3E4, bE, 3C (Motor) Action:
Apr 09, 2017 | Samsung Washing Machines
My Samsung Washer has a code of 1E which means maybe the water level. My problem is that it want turn off. Even when I push the stop button. The door is locked and it keeps beeping and flashing
1e is usually a pressure sensor error. To open the door you will need to switch off the appliance at the wall then after about 2 minutes the door should unlock. You could try the appliance again as it may just be a glitch but you will probably need the pressure sensor.
Good luck.
Dec 17, 2015 | Samsung Washing Machines
When I switch on my washing machine, it gives me the time period it will wash then it writes 1E and stops. What does that mean
1E means inlet error,your inlet valve is mechanically jammed shut & needs to be replaced.
Feb 09, 2011 | Washing Machines
How can I fix the error code 1E in my washmaching samsung SW70A1P
Error 1E is no pulse to weighing sensor to open and closed valve.
Step to solve:
1. Open top cover (behind door cover)
2. Check connecting cable of pressure switch, pull out and clean up connector (usually dirty with rust)
3. Open back cover, pull out pressure switch.
4. Clean up hose of pressure switch, blow the hose slowly.
5. install again pressure switch to the position.
6. Install cable to connector, check the current & resistant by tester.
7. Push "on" selector and fill drying position, wait until digital no blink. Running test.
8. If machine is running well closed the cover.
If still error condition (1E Error still come out), change part of "Pressure Switch" by the new one.
Regards,
Priyo
Nov 16, 2010 | Washing Machines
Had the box for nearly 1 year and have just lost all the channels.ntl samsung smt 2100c;can anyone help?
Start from scratch do the installation again.
Here are the codes for ntl
00 A9-5D-4E-FE-20-E1-2D-03
01 88-6B-69-7E-94-B6-BB-1E
These were up dated 12/10/2009
Hope this helps good luck.
Oct 13, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview codes 2/12/2008
ex cw
0=2F 1E 90 1B EA 7F A0 26
1=01 54 B4 A5 79 46 CD AA
Dec 02, 2008 | StarTech.com StarView SV211K 2-port KVM...
Ntl codes
TELEWEST
00 59 D1 52 2F 44 36 1E 7D
01 1E DF 47 38 4F FB 0B ED
WORKED FOR ME 18.40 PM ON 23RD SEPT
Sep 23, 2008 | StarTech.com StarView SV211K 2-port KVM...
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Washing Machines Logo
48 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
