Question about Ovens
How to G-hanz agneta model oven
How to pre-heat
3 Suggested Answers
SOURCE: Kenmore Model 278-4298892 Built-in oven won't heat
The oven temp. sensor has gone bad. Replace it and that will solveyour problem. The part # is WB21X5301 and cost is $73.49. Canpurchase at http://www3.sears.com/. You can view the image at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124160&brandID=0582&modelDesc=Free%20Standing%2C%20Electric&modelNumber=9114658815&documentID=00053545&documentTypeID=PLDM&documentClassCode=PM&titleType=BODY%20SECTION&titleID=00002&. It is inside the oven in the upper right or left hand corner. Shouldbe able to remove from the inside. Two phillips screws and pull it outharness also. Plug new one into harness and put screws back in and youare done.Also, on the image it is # 253.
Posted on Apr 10, 2009
toolkits
  • 1099 Answers
SOURCE: oven will not pre heat
Simple to test a bake element or range top burner element.
First, visually see if the element has molten gobs on the tubular-looking element, and/or is cracked. It will be obvious.
And if you do not see anything obvious, you should still test the element with a voltmeter. Many elements are set up so you can unscrew a screw where the element gets attached at the inside rear of the oven, and then pull the element into the stove a couple inches, enough to unhook the wires and then be able to put a voltmeter tester on each end of the element (set to the OHMS setting) to see if the element has continuity.
IF the element is good, then...
...You can also then make sure the wires are not contacting metal(BE SURE OF THIS),... and then plug the stove back in and test the wires to see if you have 220 volts. If not see, which of the two wires has 110. Then if you know which one does not have the 110, then you UNPLUG THE STOVE again and then access the rear of the stove and trace that dead wire from the element plug-in back in the range. You will physically be able to trace that wire.
When working with 220 elements in anything...please realize that usually one leg wire of the 220 volts (in other words, 110 volts) is always 'hot' even though the switch to it is off!! Always remember that!
Posted on Jun 22, 2010
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
Will not pre-heat
How old is the oven?
Did the problem start after the oven went through a, "Clean" mode?
Nov 20, 2013 | Jenn-Air JJW8527C Expressions Collection...
Upper oven will not heat up in any mode. "Pre Heat" and "On" come on for a few seconds, then go off. I checked the elements, all between 15 and 30 ohms. Every now and them it will...
Hi n664v,
This sounds to me like a Thermostat problem. If it is an electronic version Oven, then it will be the Sensor or PC Board Module controlling temperature. Please let me know what Make and Model your Oven is, so I can better assist you.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Aug 17, 2011 | Ovens
My Maytag oven works when it wants to when I heat it up it take forever and then sometimes it will stay heated at the temperature I set it at and sometimes it just quits and wont start heating again after...
The number one problem for these ovens is the ignitor. This one is your ignitor according to your model number When it is weak it is intermittent. Sometimes you can get the oven to work if you give it a swift kick. This video explains how it works:
The next likely suspect is your oven sensor. That is the link to your oven sensror according to the model number you posted. Here is a video which shows how to check it:
Jun 14, 2011 | Maytag Ovens
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Pre-Heated my oven, it beeped and I put muffins in. They began to cook and suddenly oven lost heat. When I try to pre-heat now, it clicks as if it is pre-heating but I am getting no heat. I have checked...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 10, 2010 | Kenmore Ovens
Oven takes 20 minutes to fully heat on bake - Kenmore oven plt095-2
if its a gas model most of the time you will have a weak oven ignitor. if an electric,check to see if the bake element gets hot ,some ovens will bake with upper and lower elements so if only the upper works it will take much longer to pre-heat.good luck!
Jan 16, 2010 | Kenmore Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
