Question about GE JES1039 Microwave Oven
It won't work
It doesn't work noe that i accidentally open the oven when i cooked it. How can i fix it ???
    President:
  • 3,130 Answers
Explain a little bit better please. I do not understand what you are saying. Is the oven dead? No power? Or just won't heat the food? What did you do? It says you cooked the oven?
Posted on Jun 29, 2007
SOURCE:
Wolf convection microwave
see the next steps , use the VOM and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Microwave Ovens
My Panasonic 1300w microwave will not turn off. It doesn't cook but won't turn off without actually unplugging it or opening the door and leaving it open. Any help?
You may have a shorted door switch or a shorted relay on the control board.
You can see a help file on door switches here.
Dec 01, 2012 | Panasonic NN-SN657SMicrowave Oven
Advantium 120 not working
see this causes and fix it. God bless you
If the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan.
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout, and the fan, replacing parts that don't pass the test.
Oct 15, 2012 | Maytag MMV1153A Microwave Oven
R-820js wont heat
see this causes and fix it .God bless you
f the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan. If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout (see the Applaince Controls Fix-It Guide), and the fan, replacing parts that don't pass the test.
If the oven keeps blowing fuses, check for a faulty door interlock or monitor switch.
Oct 02, 2012 | Sharp R820JS 900 Watts Convection ...
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
Don`t cook
try opening the case and checking the internal fuses. these normally cause the problem
Feb 01, 2009 | Goldstar Over-the-Range Microwave
GE JES1039 Microwave Oven Logo
59 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
