Question about Kenmore 57029 Side by Side Refrigerator
Kenmore Side-by-side refrigerator
Our power went out two nights ago for roughly 5 hours. The next morning the temperature of the refrigerator was 20 degrees and the freezer 1. Today the temps are still the same and everything in the frig is freezing. Tried to raise temp on key pad but the refrigerator temperature remains at 20 degrees. Please help!!
  • 23 Answers
Try unplugging it for 5 min and plug back in?
Posted on Jun 29, 2007
SOURCE:
H 1 Flashing
This is actually stating "HI", as in either the refrigerator or freezer, temperatures are Hi and not at a safe level. First, press any button to stop the alarm and clear the HI temperature. If you are still receiving the alarm, I suggest checking the freezer, to make sure that everything is still frozen, and nothing is defrosting as, well as checking the refrigerator temperatures. If things are defrosting or the temperature is Hi in your refrigerator, I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, Give your freezer 24 hours to stabilize at the default temperatures of 0 degrees for the freezer and 37 degrees for the refrigerator.
Mar 24, 2015 | Frigidaire Refrigerators
Freezer on side by side is not working properly
Good Morning Friend,
I understand the freezer portion is not working properly on your Frigidaire refrigerator, model# GLRS234ZA. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire GLRS234ZA Side by Side...
The freezer works but the refridgerator does not work
I understand the refrigerator portion is not working properly on your Frigidaire refrigerator. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire Refrigerators
Freezer and refrigerator are too warm
I understand that your Frigidaire refrigerator, model#FRS6R5EMB, is not cooling well. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire FRS6R5EMB Side by Side...
Yesterday morning I noticed that the unit was buzzing. The refrigerator door had been left open and the temperature inside was 70 degrees. The freezer temperature was 20 degrees. This morning, 24 hours...
Hi
You have condesation built up in your freezer whereby the evaporator fan or the vents are most likely blocked off.
Turn fridge off. Empty freezer and either put a pot of boiling water inside freezer or with the aid of a hair dryer try to defrost the freezer. If you are able to remove the back panel on the freezer that would be ideal as you can directly target the frost.
Good luck
Ash
Sep 06, 2011 | Refrigerators
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
Step 2
Step 3
Step 4
Step 5
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Our Amana was bought in 1994. It's a bottom door freezer and has been working fine until gasket was replaced (or at least, we think so). We hadn't really kept track of the temperature until we noticed...
I know this isn't very helpful, but you already know it's time for a new fridge! The life expectancy of the average refridgerator is 15 - 20 years...the good news is in todays economy, retail stores are slashing prices to increase sales, so what you would have paid a year or two ago would have been more than what you'll pay today! Happy shopping!
Oct 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kenmore 57029 Side by Side Refrigerator Logo
134 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
