Question about SanDisk Sansa e200 MP3 Player
Sandisk sansa e200
I cant put any songs on because it keeps saying please connect player put on the sansa it says connected
  • 1 more comment
  • cherish-xo Feb 01, 2008
    same with me , my sansa says its connected but when i try to add songs to it , it says to connect the device
  • Anonymous Feb 03, 2008
    According to my Sansa e200, it is connected to my computer, but everytime I open my Sansa Media Converter, it tells me no device is connected
  • shanib Feb 16, 2008
    My problem is similar, I get the same message but when I try to install it, it tells me I need to install the driver or something? Is this just because my computer is ancient?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
I cant Put any songs on my Sansa Fuze
connect the player to PC...the player's drive will be visible in "MY COMPUTER".. just right click that drive and select format option..
Sep 07, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Help me!!
mormontazzy, plug in your sansa e200 then go to "my computer" on your computer find an icon that says sansa e 200(it might say sansa e250) click on it and go to a file that appears that says media then click on the songs file after that get all of your songs from itunes and drop them into this file if tat doesn't work then take all of your songs from itunes and dropping them into widows media player
Apr 26, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e250 formatting and memory troubles
you should try putting into recovery mode. to do this, connect it to your computer, then push the hold button down so the orange is showing. Next you want to hold down the record button on the side of your mp3 player, now while holding that down also press and hold the power button. in a few seconds it should go to recovery mode. if you need more information, heres a link to the forums. http://forums.sandisk.com/sansa/board?board.id=e200
Feb 07, 2008 | SanDisk Sansa e250 MP3 Player
Problem with my sansa e200
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e200 MP3 Player
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
My sansa wouldn't work
The device needs 6MB free for each GB of music.
Delete about 10 or 15 songs and you should be all set.
Best of Luck.
Oct 30, 2007 | SanDisk Sansa e200 MP3 Player
My computer won't detect my music from my sansa e200 on my computer
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Oct 21, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e200 wont load music
Check if the player is in Autodetect/MTP then try retransferring the songs on the player. And before unplugging the player from the computer check if the files are transferred to the player click on the sansa e200 player on the left window to check if it had really transfferred the songs to the player. If it still wont work, try trasnferring songs using windows media player.
Jul 21, 2007 | SanDisk Sansa e200 MP3 Player
My sandisk e200 wont add songs
-Tha Mp3 Doctor
May 08, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
