Question about Transcend (589307) Media
How to restore regedit - Transcend (589307) Media
  • 62 Answers
You can use system restore to restore registry system restore has to be turned on
Or
Regedit can only be restored if you have backed it up you can back up by opening registey editor select registry and rightclick to use option save
Posted on Jan 22, 2009
I cant make restore points
Follow the following Steps to Create Restore Point
a. Click Start, and after that click Run.
b. type regedit, and after that hit OK.
c. place the following registry
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\VxD\VxDMon
d. Change the DelayFirstRstpt value from 1 to 0:
e. Reboot your PC.
f. Click Start, point to Programs, point to Accessories, and point to System Tools, click System Restore to start the System Restore program, and after that create a restore point.
Jul 02, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Possible fix for No Webcam
1. Start Registry Editor (Regedit.exe). START > RUN > (Type) REGEDIT (and hit ENTER) 2. Locate the UpperFilters and LowerFilters value under the following key in the registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC708002BE2092F} Write down the upper & lower filter valuse. Delete the UpperFilters and LowerFilters value (it's safe, and if could be restored later on if you have written it down, so don't worry)
on Feb 18, 2010 | Computers & Internet
Lost access to my DVD/CD ROM after updating Microsoft files. Running Vista on a Dell Inspiron 1721 laptop. Tried to delete low filter in Regedit but that filter does not exist.
you can try to searh for upperfilters in the registry and delete it. if it did not exist, kindly try to perform system restore on your computer as it is a way as well to restore the registry settings. ( restore your computer to an earlier time as the DVD/CD is still working )
May 10, 2011 | Computers & Internet
If i click the special force will sey CKI read failed 999999
i have 3 solutions
Simpliest solution is delete the actual launcher file. from your desktop and program files and copy it from your cd to the folder where you deleted it. the error just means its become corrupted please let me know if this works!
try this 2nd
Go to
Start>
Click Run
Type: regedit (if in win 7 or vista in the search bar on the start menu type regedit)
click HKEY_LOCAL_MACHINE > SOFTWARE >(DELETE MYGAME FOLDER)
Restart Your Computer
Install Special force
Patch
try this third Do System Restore in Safe Mode, if unable to do it in Normal Mode.
Try tapping F8 at startup, and from the list of startup selections, select Safe Mode by using UP Arrow Key to go there > then hit Enter.
Try a System Restore once there, to pick a Restore Point before your problem..
Click Start > Programs > Accessories > System Tools > System Restore > pick a different time > Next > etc
Mar 15, 2011 | Computers & Internet
How should i enabled my regedit?
go to start and in the RUN type regedit if it is hidden or wont open do this http://www.brothersoft.com/restore-regedit-download-194945.html
click Server 1 Brothersoft(US mirror) Click to Download
Dec 27, 2009 | Microsoft Windows XP Professional SP2
Can read Cd's but cannot read DVD's
First, try to do system restore. You can find the system restore under the Accessories folders. Just follow the interface. If fails then do the next step:
Click on start button then click on run (in Vista it will just show you the start search box) just simply type in the command "regedit" then press the enter key (in Vista once you typed in the command "regedit" in start search box, a "regedit" icon will appear on the panel just click on that to open the regedit window.
On the regedit window just follow the steps below, just click on the plus sign before the folder name:
1. Hkey_Local_Machine
2. System
3. CurrentControlSet
4. Control
5. Class
After clicking the Class folder this will populate then it will show you bunch of folders. Just look for the following folder.
{4D36E965-E325-11CE-BFC1-08002BE10318}
Once you click or selected the said folder, on the right hand side of the window will show you the information. Just simply look for "lower filters" or "upper filters" delete the two. Close the regedit window then restart the computer. If this fails do next step:
Right click on device manager, select properties then click on device manager. Inside the device manager window look for the CD/DVD ROM click on the plus sign before it then it will populate then, right click on the CD/DVD device then uninstall. Reboot the computer after. If still fails do next step:
Download and install the latest BIOS update for your system. You can download this BIOS from the DELL support site. If still fails then replace your optical drive.
Dec 13, 2009 | Dell Inspiron 6000 Notebook
System does not see the dvd or cd hardware. Loads the drivers but not the device
Hello
First create a Restore Point, now load the registry editor START-Run- Regedit. Once in Regedit goto HKEY_LOCAL_MACHINE-System-CurrentControlSet-Control-Class-4D36E965-E325-11CE-BFC1-08002BE10318. There you'll see a listing for LowerFilters and/or UpperFilters. Delete these and then restart the machine. All should be well.
Good luck
Sep 23, 2009 | Compaq Computers & Internet
My system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Administrative tools
  • Start Regedit.exe and navigate to the following locations one by one:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ User Shell Folders
-and-
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ Shell Folders
  • Delete the value named Common Administrative Tools (if present).
  • Close Regedit.exe and restart Windows.
See if the shortcuts in the Administrative Tools folder are restored. If not, see Solution 2 below.
Dec 14, 2008 | Dell Latitude C400 Notebook
About settings on my computer
you can try to restore it to an earlier time before you started adjusted the registration files. Go to Start>all programs>accessories>system tools> system restore and choose a date before you started adjusting the files. The computer will restore and reboot. If this does not help you resolve the regedit.exe problem then I suggest booting from cd rom and selecting Repair. This will restore any windows files that has been corrupted or deleted.
I hope this helps
Nov 14, 2008 | Microsoft Windows XP Home Edition
Transcend (589307) Media Logo
453 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
