Question about Kenwood Audio Players & Recorders
Kenwood vr206 no signal to my sub woofer
I have the sub woofer connected to the out from the receiver but no sound is coming out from the sub.
SOURCE: AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Posted on Jan 04, 2008
  • 979 Answers
SOURCE: have a kenwood a85 amp
Make sure that you have Speaker A or B selected...accordianman
Posted on May 01, 2008
  • 18 Answers
SOURCE: connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Posted on Mar 03, 2009
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
smarthome2
  • 1114 Answers
SOURCE: No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
Posted on May 24, 2009
I want to connect kenwood woofer sw-07 to pioneer amplifier vsx-d859tx. i am unable to connect please guide me.
I don't recall correctly if your Pioneer has a sub out RCA connector, and if the Kenwood SW-07 has a low level input. So the usual way is to connect it using the speaker wires.
You connect either the FL or the FR to the sub and it should work.
Good luck
Jan 11, 2015 | Pioneer Audio Players & Recorders
I have no sound coming out of my sub woofer on my kenwood VR-407 everything else works great anyone have any ideas or solutions
yes it very much has everything to with it. your sub out is at a pre-amp lvl, so you can route that signal to another amp, then to your passive sub, or get a powered sub
Apr 19, 2013 | Kenwood VR-407 Receiver
How do i connect the sub woofer for kenwood-505
I inherited a Kenwood SW 505 Sub woofer. I don't know if it works I plug it in but no lights.
Oct 07, 2012 | Kenwood VR-505 Receiver
Sub woofer output port does not seem to work on my kenwood VR 407, checked sub woofer on another system - works fine, any easy solutions?
Is the 407 set up to drive the unknown sub. It's not just plug n play.
The manual will guide you, around page 15. Also refer to your subwoofer manual. Try retrevo.com for that one.
http://www.retrevo.com/support/Kenwood-VR-407-Receivers-manual/id/480ag200/t/2/
Dec 29, 2010 | Kenwood VR-407 Receiver
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
Connecting 2 sub woofers to denon 1506 receiver
Mar 03, 2009 | Denon AVR-1506 Receiver
Hooking up my sub woofer
Hi ..
According to the manual there's a pre-out (phono style RCA) connector for the sub but it needs to be a powered subwoofer..Has its' own internal amp
Jul 26, 2008 | Kenwood VR-305
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
26 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
