Question about Zanussi 24 in. ZSF6120 Free-standing Dishwasher
No hot water
My dishwasher is not washing properly due to no hot water,. I am lead to believe that the problem could be the heating element, but where in the dishwasher can I find the heatin element.
Thank you
  • 4,472 Answers
First off how long have you owned the unit and how long have you been experiencing this problem. Most likely if you don't know where to find the heating element this job is best left to a professional.
http://www.serviceforce.co.uk/index.asp
follow this link to inquire about service and an estimate as to the price of service. If you need further assistance please let me know, also please take a moment to accept and rate my solution accordingly.
Thank you,
lee
Posted on Jan 20, 2009
    President:
  • 2,559 Answers
The hot water in the dish washer is supplied by the hot water heat in your house,The element is only for drying.
Please check that you have hot water at the kitchen sink.
Also, this a new install,replacement or has it been there for some time and was previously working with hot water?
Model 587.14134102 dishwasher is not cleaning well. Unpon checking it by opening it up during various cycles the water does not seem hot enough. The dishes are warm to the touch but not hot. How can I...
Does your machine take in hot or cold water. If it takes in hot water the element that heats and maintains the heat may be defective. If it takes in cold water the element is heating it but the thermostat is cutting out the element at too low a temperature. Normally dishwashers take in cold water and heat it to the required temperature, which would mean that the thermostat is faulty?
Feb 06, 2011 | Kenmore Dishwashers
Should be connected dishwasher only to hot water?
Connect it to cold water line only, never the hot line, the dishwasher has its own heating element to heat the water to the proper temperature for a clean and sanitized wash.
Jan 03, 2011 | Bosch Dishwashers
Water not hot enough. Supply water is plenty hot but washing water is not hot.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 12, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
What does a thermometer symbol with up arrow mean on an shx68
Hello Jsg5,
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Bosch Integra 800 SHX68M0xUC Dishwasher
I have hot air but no hot water in my dishwasher
Check to make sure your supply lines aren't crossed and that your hot water supply is connected to the dishwasher
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
GE Dishwasher SSD3900J00ww wash water cool heating element hot on
Crew that installed new cabinets and sink hooked dishwasher to cold water line I switch it works fine now. Thanks Don
Mar 20, 2009 | GE Dishwashers
Does a LG model LDF 6920st have anything way to heat to hot water
Dishwashers do have a water heater element. In fact, it's the same heater that is used for hot dry, but you can switch it off for the drying cycle if you want. Dishwashers heat the water so it will be hot enough to properly clean the dishes. Sorry, you lose the bet.
Nov 26, 2008 | LG Dishwashers
Unit never washes...
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be about 1/4 to 1/8 inch below the heating element. If not there..replace water inlet valve.
Jun 17, 2008 | Whirlpool 24 in. GU2548XTP Built-in...
Zanussi 24 in. ZSF6120 Free-standing Dishwasher Logo
120 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
