Question about Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-5200T problem
Greetings all,
I recently just purchased this amp second hand, however I wired it up to my original setup and replaced my weaker amp. But the output from this Pioneer 5200t is very low, no bass at all but you can just hear it.
Cannot be the wiring as when I switch it over to my old amp it goes fine.
Could the transistors etc been blown?
Thanks any help will be very much appreciated.
  • Anonymous May 02, 2009
    were can i get parts for my pioneer gm5300t i
  • 67 Answers
I dont think transistors are bad . you should check the amp controlls they may need adjusting
Posted on Jan 20, 2009
    New Friend:
90% your transistor is defective you have to replace it......
Posted on Mar 19, 2013
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
Subwoofer pulses
amp is probably bad. i call this "motor boating". especially if it is a constant pulse. 9 times out of 10 the amp is the problem with this. rarely is the radio the problem.
Dec 26, 2009 | Pioneer GM-5200T Car Audio Amplifier
Amp worked the stoped...
check every connection with a volt meter to see where u r losing power
Jul 04, 2009 | Pioneer GM-5200T Car Audio Amplifier
I was hocking up a other amp to my first one and to wiers toched and the red ligt came on and it makes no noise
possible not compatable with each other, wrong amount amp, too much power that cause it to disable amp (protection)
Apr 17, 2009 | Pioneer GM-5200T Car Audio Amplifier
Keep blowing fuse under hood when i put power wire in to amp
disconnect the negative battery terminal, replace the fuse with all the wires hooked up to the amp and reconnect the battery terminal, that way the initial surge of power goes through the negative terminal and not your inline fuse. That should solve your problem.
Mar 29, 2009 | Pioneer GM-5200T Car Audio Amplifier
No sound from amp
THIS IS AN EASY FIX. DISCONNECT THE POWER WIRE FROM BATTERY. REMOVE THE GROUND WIRE FROM THE CARS BODY. SAND ALL THE PAINT AWAY FROM THAT AREA. WIPE IT CLEAN WITH A DRY CLOTH AND HOOK THE GROUND BACK UP. THEN RECONNECT THE POWER WIRE AND THAT SHOULD FIX IT. IF NOT THEN TURN DOWN UR GAIN CAUSE THE AMP IS OVER HEATING
Feb 19, 2009 | Pioneer GM-5200T Car Audio Amplifier
Red light on my amp?
Does the amp power up normally if you disconnect the speaker wires from the speaker terminals of the amp?
It's never a good thing to blindly short across a power source.
May 22, 2008 | Pioneer GM-5200T Car Audio Amplifier
POWER
short in the system, or bad ground, or connections?
Oct 22, 2007 | Pioneer GM-5200T Car Audio Amplifier
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-5200T Car Audio Amplifier Logo
257 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
