Question about HP Mini 110-1037NR Netbook
HP mini 110 makes occasional buzzing noise even without battery
Has just starting making buzzing/vibrating sound from keyboard front right hand corner near the wireless light/switch. Noise still happens after completely disconnecting all power.
adib
  • 450 Answers
SOURCE: AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Posted on Sep 12, 2005
Khalsa007
  • 79 Answers
SOURCE: My HP 2610 copier is making a strange crackling noise which is new...what's causing this?
HI,
Perform a semi-full reset on the all-in-one by following the steps below
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the all-in-one.
  3. Wait 30 seconds, and plug the power cord back into the wall outlet.
  4. Press and hold the # and 6 buttons on the numeric keypad.
  5. While still holding the buttons, plug the power cord back in to the all-in-one. Continue to hold the buttons for two seconds, and then release them
  6. Allow the all-in-one to re-initialize. This may take a minute or two.
  7. If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
Note - you can also try the Ok n cancel key combination in place of # and 6 .
u can also try the following steps >>
u can press set up on the printer > go to the tools option [ by pressing the down arrow key ] > press ok > go to clean print head , clean cartridge , allign printer > it will service the product .
The problem should be corrected. If the problem still exists, service your product.
Thanks
Posted on May 30, 2008
SOURCE: Blue buttons (quickplay/sound/dvd controls) won't work
Mine did that as well then after rebooting started working??
Posted on Aug 16, 2008
SOURCE: HP Pavillion dv6000 - dark screen, no power noise, but power lights are on
1) Turn off your laptop.  2) Remove Power supply.  3) Remove the battery and put it back again after 1 min.  4) Put power back and restart.
This should solve the porblem ! I have had it several times.
Posted on Nov 29, 2008
  • 75 Answers
SOURCE: HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Posted on Jan 07, 2009
Samsung dishwasher makes a loud buzzing sound when the water is filling. It pulses a couple times to start then is constant. It pulses again right before the wash cycle. Comes from the bottom left.
This is common. The noise is coming from the water pump. If it bothers you, you can try UNPLUGGING the washer or turn off the Circuit breaker first. Then you can remove the bottom kickplate on the front of the washer and clean around the pump. If there is a water filter scree, clean it out. Make sure there is nothing rubbing against the pump which could cause a buzz. Tighten all fittings and screws to eliminate vibration noise.
Aug 30, 2015 | Samsung Dishwashers
I can't working with keyboard HP mini 110 RN
Buy a new keyboard and make the substitution
Jun 21, 2012 | HP Mini 110-1037NR Netbook
How to remove the keyboard of a HP Mini 110 3130sv
Removing the Damaged Keyboard
1. Enusre the laptop is fully powered off, unplugged laptop ac adapter from the wall, and the battery taken out.
2. Turn the laptop over. On some models icons indicating which screws are attached to the keyboard for HP Mini 110-3130sv displayed. If not, you may have to "eyeball" it if you can't find a breakdown for your model online.
3. Remove those screws with a T-8 or Phillips screwdriver.
4. Turn the laptop back over and open it up. Check and see if the HP laptop keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
5. Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
6. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, ribbon cable to the system board at the bottom.
7. Take that same pick and lift the plastic connectors that hold in this data cable in place.
8. Carefully remove the data cable. Now the whole HP Mini 110-3130sv replacement keyboard should be free.
Replacing the keyboard.
1. Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
2. Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
3. Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
4. Refasten the keyboard in place at the top.
5. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
6. Turn the laptop over and replace all of the keyboard screws.
7. Finally, put the battery back in and power on the laptop. If all has gone well, the HP Mini 110-3130sv Keyboard should be functioning like brand new.
Sep 01, 2011 | HEWLETT-PACKARD Mini 110-1031NR Netbook
I have a HP Mini 110-1116NR PC it wont turn on No lights or any thing
Possibilities are inmense, first make sure that your power supply is working, remember that its what charge the whole thing up. if power supply is not giving the right voltage the the lithium battery is not charging. You may have to take it to your local computer shop yo check it
Dec 16, 2010 | HP Mini 1000 Netbook
2000 Nissan Maxima Noise My maxima is making a weird sound like a 1920's car horn, like a rubbing sound or a mechanical rubbing, robotic almost. I already changed the Brakes, and the wheel bearing and it...
sounds like a ride controll compressor if your car has air ride controll it will have a compressor
check the fan for bad blades and chips also check the fan housing for missing hold downs and screws also for clearences and if loose or out of mounts
Jan 23, 2010 | 2000 Nissan Maxima
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
My new Razar V3a makes buzzing sound
If the buzzing is coming from the keyboard then it's a known problem/feature. Got the same on mine when the keypad is lit up, so rag Motorola, who said sorry, known feature with that model.
Aug 29, 2007 | Motorola Mobility RAZR V3
Sony DCR-HC42 makes a buzzing sound
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
HP Mini 110-1037NR Netbook Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
