Question about Microsoft Windows XP Professional
Partition parameter hello I used partition magic to split a filled partition(D:) into 2 parts D: and K:. After I reboot the D: partition became a RAW partition nad says parameter is incorrect and does not opens(no properties).In Partition Magic the D: part shows up having previous data but the computer Management shows the partion without File system and completely empty. The K:partition shows in the computer management with FAT32 type but does not shows up in My computer. when tried to merge them again using Partition Magic it requires a format of D:. Is there still Data left in D: ? How will K:show up ?
    Problem Solver:
  • 17 Answers
From the data you provided, the D drive is deleted and is newly created. But it is not yet formatted. So the data is virtually deleted. Why I said virtually is because, the data is still there on the drive physically and you can recover it using third party tools like OO disk recovery tool. That is why partition magic is still showing data on it.
And it is also obvious that the task which Partition Magic started (splitting drives) is not finished properly. That is why K partition is incorrectly formatted. It is natural that it asks format of D drive because D drive belongs to no file type and it must be of FAT32 or NTFS or other file system.
The solution for your problem is try recovering your data on D drive using disk recovery tools. Then format it using FAT32 or NTFS. Format K drive also in FAT32 or NTFS. Use either partition magic or Computer Management. Since already PM caused problems on your computer, try computer management. It is safe.
Posted on Jan 20, 2009
Missing Operating System on D: partition Bootup
Follow the steps from this site http://www.wikihow.com/Change-the-Active-Partition-of-Your-Hard-Disk-with-Parted-Magic. When you changed the active partition you told the computer to look for information from the wrong partition. Using the program from that site will allow you to make the other partition active again. You'll then be able to boot into Windows again. As far as making backup discs, I believe you hit F11 while booting to access the recovery partition. From there you can make your recovery discs. Not 100 percent sure on that though. And you will need to get the windows partition set back as active first.
Jun 19, 2013 | HP ProBook 4510s FM849UT Notebook
C drive too full
If there is a large number of unused space on other partition you could directly allocate the free space the your system partition, but keep in mind backup your important files is recommended no matter which way you use when re-partition hard drive, learn more from this link: http://www.extend-partition.com/help/allocate-free-space.html
Aug 09, 2012 | Computers & Internet
My hard drive has been split, how do I make it back into one?
You can delete both partitions and then create a single partition and then format the partition.
If you do not want to delete the partitions and lose your data then you can use a program called Partition Magic to resize your main partition so it is a single partition.
Dec 11, 2011 | LaCie Computers & Internet
Unable to merge c and d drives
Dear! Use partition magic v8.0 or 8.2 softwawre, there is very easy to merge your drives.
Good Luck
Sep 28, 2009 | ASUS Eee 4G Notebook
Rules for runing partitiom magic
The FixYa Team
Thanks for the respone
I have been informed by the VISTAHEAD admin. that vista can not be partitioned by more than 4 parts.
I used the shrink function available in the Vista computer manger , rename the DVD drive label, and labeling the new partitions, then format them as NTFS, then reboot twise for taking the configuration setup and every thing is o.K. without the need for the partition magic.
Now i have only 4 patitions. But didn't know why is this limit?
Beside that i read that the partition magic v8.0 cannt partiton the vista O.S main drive.
Thanks
Abo_Anas
Feb 02, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Partition problem
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
Jan 20, 2009 | Microsoft Windows XP Professional
Partition Problem
Yuou must backup the data of d:\ in another harddrive or volume before doing this backup your data in another volume and then merge the data you can even copy the sectors from partion magic .Data can be recovered by using data recovery softwares.
Cant reboot win.98se after using partition magic 6.0 to merge adjacent partition to c. drive
how large the capacity of your hard disk drive? it is possible that would be the problem it is too dangerous that it will lead your hard disk to crash the system and damage the disk itseld that can create bad sectors on your disk. If you want to partition your hard drive, run the FDISK utility instead.
Feb 07, 2008 | Dell Dimension 3000 PC Desktop
Splitting a 80 gig hdd into 2 sections
Hello douglasc, You will have to repartition your hard drive. I would suggest the use of an application called partition magic. It will allow you to partition your hard drive even though the OS is present on the system. It does this by first defragmenting your hard drive and the putting the unused sectors together and the used sectors together this way it makes the division of the sections easier. Now once the hard drive is defragmented it allows you to section the drive into different logical hard drives. Follow the instructions from the documentation and you will have a successful repartitioning. Thank you, Shuttle83
Oct 08, 2007 | Audio Players & Recorders
Microsoft Windows XP Professional Logo
149 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
