My hisense HAIR24HN will only blow out warm air and not cool air?
Our hisense air conditioner will turn on but only the fan works, it will not blow out cool air. Is there a part which needs replacing?
  • 9 Answers
SOURCE: Delonghi Pinguin Air Conditioner
I sat on hold with Delonghi for about 25 minutes before I talked to someone this morning.  Expect a long wait before you get helped.
For this specific problem (unit works, just doesn't blow cold air), the unit MUST be sent to an authorized repair facility.  No repair facilities in Texas.  The closest one to Texas is:
All-Brands Appliance 5008 W. Linebaugh Ave. Suite #8 Tampa, Florida 33624 813-908-2002
Delonghi said they will cover mine under full warranty up to 13-months.  No RMA needed, just a photo copy of the purchase receipt for the unit. Outbound shipping is something not covered by Delonghi, but they will pay for parts, labor, and return shipping.
All-Brands said they don't have any specific requirements for packing, other than making sure the casters on the bottom of the unit are well-protected.  It is common for them to break during shipping.  They recommended, though, that if you have someplace nearby that does professional packing, like a UPS Store, to take it there.  It's not a requirement, just a recommendation.
Along with the unit send a copy (not the original) of your purchase receipt, your name and telephone number, and the address to where the unit will be returned.  Also, include a detailed description of the problem with your unit.
I REALLY hope this information helps someone!
Posted on Jun 09, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 18 Answers
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
  • 17 Answers
SOURCE: My Ruud Air Conditioner Model UAMB-048JAZ is not blowing cool air
3 things it could be:
#1 problem with AC units - dirty coils, this leads to many other problems and is caused by neglecting to change filters monthly. You can buy coil cleaner commercially, but it is not the coils you see that get dirty. There is another set inside that is usually not visible. If you look outside and your unit is "iced up" there is a 98% chance that is your problem. Sometimes it could be iced and you can't see it from the outside. Solution, turn AC off and blow fan to thaw. When thawed, clean coils with coil cleaner and coil comb.
Relay switches, you already pushed it so you may have a bad switch.
These are the two most common problems. A mechanic will be quickl to say it is your compressor for $. There are normally only half a dozen things that go wrong if your AC is 10yrs or less. If it is over that, it could possibly have a more serious problem. (Secret hint - I have known AC's to last 30+ years if the filters are changed regularly. Letting dust and dirt build up on coils invites a host of other problems due to the stress it puts on the other components.
Posted on Aug 30, 2009
  • 232 Answers
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Posted on Sep 20, 2009
I have a 2002 Volvo S60 air conditioning problem. Initially, the air conditioner will blow cool/cold air, but when I get in traffic and have to do a lot of stopping and starting the air turns warm. Have...
check to see if your cooling fans are working because when they dont work, your air will blow nice and cold when driving but will be hot air when stopped in traffic.
Jun 15, 2011 | 2002 Volvo S60
My air conditioner makes a weird noise when I turn the fan on and it will not blow cool air.
will the fan run? Is the air warm, is there no air? it won't cool if the fan won't circulate air across the cooling coil. You may have a fan problem
Oct 07, 2010 | 2002 Subaru Outback
Takes times it will blow cold air no matter what, fan not working, then fan finaly kicks on and we get warm air.what is wrong?
Bad sequencer. An a/c tech will have to replace this sequencer due to the complications of installation.
Dave
Jan 08, 2010 | Goodman CLQ36AR49 Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
No cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
Jul 02, 2009 | Amana Heating & Cooling
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
On/off cooling
You will need to replace the outdoor fan and capacitor before it cause damage to the compressor. Thx RepairUSA
Aug 25, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
