Question about Kenmore Vacuums
Manual for Whispertone 300 Model 116.28612790
Do you have manual for this Kenmore canister vacuum?
reddevil6
  • 1673 Answers
SOURCE: vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Posted on Jan 14, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
Vac Belts
  • 701 Answers
SOURCE: Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Posted on Oct 29, 2009
SOURCE: need manual for kenmore canister vacuum model
Try www.managemyhome.com I found my manual there
Posted on Mar 08, 2010
  • 144 Answers
SOURCE: kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Posted on Mar 30, 2010
Manual for kenmore whispertone 300
Which specific model in the WhisperTone line do you have? The manual may be available from Sears Parts Direct. Start here: http://www.searspartsdirect.com/partsdirect/user-manuals .
The manual for the Kenmore 116.27512790 canister vacuum is available here: http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807641.pdf . This may be useful if the vacuum is similar to yours.
I hope this helps.
Dec 21, 2014 | Kenmore Vacuums
I need to know what bag to buy for a whispertone canister vacuum.
You need Kenmore "C" bags, the part number for a pack of 8 is 50104
Dec 07, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Help! i have a whispertone 300 model 116 28612790. the retractable cord is jammed & i could only get the front part of the canister open that houses the motor, etc. there are only 2 screws to open it...
even if you get it apart chances are it needs a new spring but it requires a special tool to get the rubber molding off that separates the top from bottom and sears repair guys and vacuum shops have them. I would take it to a used vac store and get them to fix it before you try yo remove the rubber seal as it will not go back on well and that will cause the machine to not get aproper seal and lose airflow.
Oct 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Feb 13, 2010 | Kenmore 24212 Whispertone Bagged Canister...
I have a kenmore whispertone 5.1 and need to find out if it has a hepa filter. I don't think so..... Thank you!
Hi If its the same as the one shown here:
http://cgi.ebay.com/KENMORE-WHISPERTONE-12AMP-HEPA-VACUUM-WARRANTY-AVE_W0QQitemZ310151428708QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836773a64&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
That model has a HEPA filter.
Otherwise the older models don't have them and rely purely on Allergy bags that you can buy for your vacuum.
Jun 27, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Vacuums Logo
75 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
