Draw a flowchart to accept two numbers and any one of the following characters: +, -, *, or /. Based on the character entered, the numbers should be added, subtracted, multiplied, or divided and the result should be displayed.
airoff
  • 160 Answers
SOURCE: flowcharting
Input FirstNumber
Input SecondNumber
Sum= FirstNumber + SecondNumber
If FirstNumber > SecondNumber
Diff=FirstNumber-SecondNumber
Else
Diff=SecondNumber - FirstNumber
END IF
Product = FirstNumber * SecondNumber
Posted on Jul 16, 2008
onlybrosh
  • 284 Answers
SOURCE: draw a flowchart to enter
work with array . arr[1] = Sunday , arr[7] = Saturday
Posted on Mar 14, 2011
SOURCE: draw a flowchart to accept
draw flowchart of this solution
Posted on Feb 06, 2011
  • 3 Answers
SOURCE: draw a flowchart to enter a number from 1 to 7 and
Dunno what language you need but it'd be a simple:
User Input -> if 1 -> "Sunday" '-> else if 2 -> "Monday" '-> else if 3 -> "Tuesday" '-> else if 4 -> "Wednesday" '-> else if 5 -> "Thursday" '-> else if 6 -> "Friday" '-> else if 7 -> "Saturday" '-> else -> "Invalid input entered"
Posted on Mar 05, 2011
  • 96 Answers
1 rem zero out all variables housekeeping
10 let a=0
15 clear $today
16 rem get input
17 input a
19 rem choose corresponding day of the week
20 rem case structure
25 if a=1 then $today="sunday"
30 if a=2 then $today="tuesday"
rem ect til saturday
rem use data created
40 print "today is";$today
Posted on Apr 27, 2011
How to get the sterling pound symbol in K120 logitech keyboard
Entering the following keystroke combination will result in the Pound Sterling sign being displayed:
While holding down the ALT key, enter 0163 (ALT+0163).
This is known ASCII Code. (Pronounced Ask-key.)
A complete list of all 256 character codes is available at http://www.ascii-code.com/ .
All manner of Latin-based characters are available. Check it out.
To use any ASCII Code, choose the "HTML Number" and substitute "ALT+0" for "&#".
In this case, the HTML Number is &#163, therefore when entering text, type ALT+0163 (NOTE: "ALT+" means "While holding down the ALT key, press and release each of the four digits in sequence, then release the ALT key.)
Hope this helps.
Sep 02, 2014 | Logitech K120 USB Keyboard
Tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
on Nov 11, 2013 | Microsoft Excel Computers & Internet
Nov 25, 2013 | Cagiva Raptor 1000 Motorcycles
I want to fax from new zealand to australia. how about i do it...........
In the setup you should enter your the fax number in the internationally standardised format, i.e.
in accordance with the following strict sequence:
??  The "+" (plus) character (by pressing
key)
??  Your Country Code( "64" for New Zealand)
??  Your local area code minus any leading "0"
??  A space
??  Your number on the local exchange, using spaces to aid readability as appropriate.
1 Press Menu/Set, 0, 3.
2 Enter your fax number (up to 20 characters).
Press Menu/Set.
3 Enter your telephone number (up to 20 characters).
Press Menu/Set. (If the telephone number and fax number are the same, enter the same number again.)
Note
??  You cannot enter a hyphen in the number.
To enter a space press once between numbers.
??  The telephone number you enter is only used for Cover Page features.
4 Use the dial pad to enter your name (up to 20 characters).
Press Menu/Set.
5 Press Stop/Exit.
Note
If the Station ID has already been
programmed, the LCD will ask you to press 1
to make a change or 2 to exit without
changing.
3.Station ID
??²
Now dial the fax number of australia 0061............ and send fax.
Jun 02, 2011 | Brother IntelliFax-2820 Laser Fax
I have a kyocera loft virgin mobile phone. I am entering all my information to set up my mobile web. When I go to enter my password it only accepts the first 7 of my password and I have 9 characters. So I...
I currently don't have an answer as to why your Kyocera only accepts 7 characters of your password but I have a simple fix that could solve your issue. Just access your email first using a computer then change your password from 9 characters to 7 characters long. In this way, once you set up your Kyocera and enter your email password, it would accept it and would be able to receive your emails.
Hope this helps.
Mar 25, 2011 | Cell Phones
Can't connect with microsoft MN-510 using WPA
This means that you have to enter the network key into your computer in order to connect to the network,
If you enter the password as hexadecimal characters, you must type exactly 10 characters (5 bytes) for a 40-bit key (valid characters are 0-9 and a-f), or exactly 26 characters (13 bytes) for a 104-bit key.
If you typed any number of characters other than 10 or 26, or any character that is not a hexadecimal digit, this is interpreted as ascii string.
In this mode, each character is a byte by itself.
So, valid length of the string in this case is either 5 or 13 characters.
If this condition is not met, the string can't be accepted as a valid password.
Please check carefully what you type. (Letter O instead if zero, or small L instead of 1 etc.)
If you don't know the key, you have to connect to the router via a cable and copy the key from there - or ask your Dad to give you the information. He will have it, because he has a working connection.
If you have any more questions or this is not clear ot you, just come back here and leave a comment - I'm happy to help.
May 29, 2009 | Microsoft Broadband Networking MN-500...
Form creat in flash
  1. Create a new document and set the size to 400 x 300 ("Frame" > "Frame Size")
  2. Set "Frame 1" to "Stop" ("Frame" > "Frame Delay" and check "Stop", click OK)
  3. Draw 2 edit fields with the "Edit field" tool, they will appear as Edit1 and Edit2. Double click each field and make sure HTML is not checked, uncheck if necessary.
  4. Draw a button, double-click it and rename it to "OK".
  5. Draw edit field labels "Phone" and "Email" with the text tool. Double click each field and make sure HTML is not checked, uncheck if necessary.
  6. Draw "ErrorMessage" field with the "Text Paragraph" tool. Choose "Item" > "Text Color" and change it to red. Choose "Item" > "Placement Properties" and rename the field to "ErrorMessage"
    1. Select the button, choose "Item" > "Actions" > "OnClick". Select "ActionScript" and paste the following code:
    // reset error message
    ErrorMessage = "";
    // validate phone field
    phone = Edit1;
    if(phone=="") ErrorMessage = "Enter your phone";
    // validate email field
    email = Edit2;
    if(email=="") ErrorMessage = "Enter your email";
    if(email.indexOf("@",0)<0) ErrorMessage = "Enter valid email";
    if(email.indexOf(".",0)<0) ErrorMessage = "Enter valid email";
    // build message string
    message = "mailto:support@selteco.com?subject=Title&body=Form contents%0A";
    message = message + "phone: " + phone + "%0A";
    message = message + "email: " + email;
    // execute form if errormessage is empty
    if(ErrorMessage=="") getURL(message,"_self");
Hit F9 to preview. The form will not work until you export Flash file and HTML page. Choose "File" > "Export HTML Page" to create HTML page and test the form in a browser. This form is using very basic validation. Use "%0A" as line separator.
Use the following functions or attributes of the string:
  • length returns the number of characters
  • charAt(x) returns zero-based character at position x
  • indexOf(substring,startindex) returns the position of the first occurrence of the specified substring or -1.
  • lastIndexOf(substring,startindex) returns the position of the last occurrence of the specified substring or -1.
  • substr(start,n) returns n characters string starting at specified position
  • toLowerCase(), toUpperCase() converts the string to lower or upper case
Jan 21, 2009 | Computers & Internet
225 mr will not play burn MP3's
I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you. Acceptable medium formats: The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses. ? ISO 9660 Level 1 (12 characters) ? ISO 9660 Level 2 (31 characters) ? Joliet (64 character; Up to 32 characters are displayed) ? Romeo (128 character; Up to 64 characters are displayed) ? Long file name (200 characters; Up to 64 characters are displayed) ? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed) For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below. The media reproducible on this unit has the following limitations: ? Maximum number of directory levels: 8 ? Maximum number of files per folder: 255 ? Maximum number of folders: 50 MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed. Settings for your MP3/WMA encoder and CD writer Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder. ? Transfer bit rate MP3: 8 ?320 kbps WMA: 48 ?192 kbps ? Sampling frequency MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz WMA: 32, 44.1, 48 kHz When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once. Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used. Entering ID3 tag: The Displayable ID3 tag is ID3 version 1.x. For the character code, refer to the List of Codes. Entering file and folder names: The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA). A file with a name entered with characters not on the code list may not play correctly. Writing files into a medium: When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers. ? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension. The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension. ? Do not attempt to play a medium containing non MP3/WMA.
Jul 31, 2007 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Keyboard data entry
Sounds like a classic problem for a driver/firmware update. get an update here before trying anything else- http://www.palm.com/us/support/downloads/tungstenc/tungstenc_update_30.html If it still doesn't solve it you might need to format it and reinstall everything from scratch. Good luck
Apr 22, 2006 | Palm Tungsten C Handheld
Computers & Internet Logo
349 people viewed this question
David Payne
David Payne
