Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer loud, arethere bearings to grease? Bought from neighbor don't have manual. Any options other then repair charge and service charge
Sounds like a jet engine. Sound has been the same from first load till now. The noise hasn't gotten any louder
    Sergeant:
  • 291 Answers
Yes there are bearings, but not greasable. Have to be replaced.
Posted on Jan 07, 2013
  • B.H. Countryman Jan 07, 2013
    You can go to www.searspartsdirect.com and type your full model number into the long search bar. Choose search for model # in dropdown in short search bar. Hit search tab. Usually a manual is available.
    Also You Tube now has peeps replacing bearings for our viewing pleasure.
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
cactus bob
  • 267 Answers
SOURCE: KENMORE FRONT LOAD WASHER - PULL THE SHAFT OUT OF THE BEARINGS.
NO , if there is damage to the shaft you will need a drum BIG $$$$$$$$
Posted on Jan 17, 2009
Karthik316
  • 187 Answers
SOURCE: loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
  • 2468 Answers
SOURCE: loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Posted on Mar 05, 2010
Grease fittings for spindles
Some cheaper mowers don't have grease zirks for the spindle bearings. If you cleaned off the deck and you can't see them, the only thing to do is remove some shields and keep looking, or check with manufacturer details to see if it even has them. A simple call to a craftsman repair shop should be able to answer that question.
May 22, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Spinning cycle noise and F1 code
I wrote the comment about the jet engine noise and the F1 code on my WTW6600W Cabrio washer. Today I called Whirlpool Service at 800-253-1301 and have your model and serial numbers ready. I mentioned the F1 problem first and then explained about the noise. She did a little research and informed me that the F1 problem and the bearings problem are connected and she arranged their service people to repair both at no charge to us! It's so worth the call, we almost bought a new washer. HUGE SURPRISE!!
Sep 08, 2012 | Whirlpool Cabrio Washing Machines
Dryer making a loud skreetching noise
Sounds like either a Frigidaire or model 417 kenmore. If it is the rear bearing has gone bad. Usually just the bearing cup needs replacing as long as you don't forget to use the proper grease.
Jan 26, 2010 | Dryers
Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
May 07, 2009 | Whirlpool Inglis IP4400 Washer
Grease on clothes
Check to see if you have movement up and down on the inner tub like a bad bearing or loud roaring noise when turning by hand if so your bearing in the back of the unit has washed its grease out and the back of the outer tub will have to be replace the bearing in factory pressed in sorry that is a hard job and not a cheep one good luck
Mar 29, 2009 | Kenmore 43142 Front Load Washer
Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Feb 18, 2008 | Kenmore 23822 Top Load Washer
Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Nov 07, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite Oasis 27052 Top Load Washer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
