Question about Yahoo Messenger
I am not able to open the yahoo messenger. I am using vista os.
    Problem Solver:
  • 3 Answers
This was a problem reported when vista was first introduced. You can try downloading the latest vesion of yahoo mess..hope it should work.
Posted on Jan 20, 2009
I cant open my hide messesages in yahoo messenger it says a runtime error
You do not give your OS or a copy of the Runtime Error
Most Runtime errors in Messenger will be IE
IE is coded with Messenger and has to be kept clean and up to date
XP.
http://support.microsoft.com/kb/822521
Vista
http://support.microsoft.com/kb/923737
Sep 10, 2010 | Yahoo Messenger
I cant install yahoo messenger 10 ...plz help
for Windows OS: If your installation stuck on finishing installation, just terminate the process. Use CTRL+ALT+DEL and kill YM10SETUP process. I'm sure it would be around 95% in completing installation. You can start using it by click on yahoo messenger icon on desktop or by clicking on START menu. By doing this, you can use yahoo messenger like usual. If there's problem happens, you must re-install yahoo messenger or otherwise you'll keep faces the problem over again.
Jan 07, 2010 | Yahoo Messenger
My Yahoo Messenger keeps closing
my yahoo messenger keeps closing (crashinggraying out or sleeping not able to open to do instant messeging
Nov 28, 2009 | Yahoo Messenger
Why can't I install yahoo messenger 10.0 successfully? after attempting to install, an error will prompt which says ''yahoo messenger did not install properly; this may be due to an open application or...
You need the following OS to support Messenger
Windows 2000/XP/2003/Vista/XP64/Vista64
If that is not an issue read on.
The problem may be due to a mal-function of the uninstall software.
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall from the Control Panel and failed to back it up with a visit to the C drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Nov 20, 2009 | Yahoo Messenger
It wont llet me downlaod yahoo messager
uninstall the previous version through these steps:
XP OS To do so, kindly follow these steps: 1. Click the "Start" menu and select "Run." 2. Type "appwiz.cpl" and press "OK." (This is a shortcut to "Add or Remove Programs.") 3. Select "Yahoo! Messenger" and click "Change/Remove." 4. In the window that opens, click "Finish" to uninstall. 5. Click the "Start" menu and select "Run" again. 6. Type in "%ProgramFiles%\Yahoo!\" and press Enter. 7. Delete the "Messenger" folder.
VISTA OS 1. Click the "Start" menu and select "Run." If you do not see the Run command, then select Start > All Programs > Accessories > Run. 2. Type in "appwiz.cpl" and press Enter. This opens "Programs and Features." 3. Select "Yahoo! Messenger" and click "Uninstall." 4. Click the "Start" menu and select "Run" again. 5. Type in "%ProgramFiles%\Yahoo!\" and press Enter. 6. Delete the "Messenger" folder.
Disable anti-virus and firewall before reinstalling using this link:
http://download.yahoo.com/dl/msgr10/us/ymsgr10us.exe
Oct 09, 2009 | Yahoo Messenger
My yahooo messenger doesnot open
disable your firewall and anti-virus then uninstall current version through these steps:
XP OS
VISTA OS
Reinstall using this link:
Sep 24, 2009 | Yahoo Messenger
My yahoo messenger is not opening but it running in the process
At first you should find the source of problem, yahoo messenger? OS? or maybe Server!
But I think it comes from your yahoo messenger, please remove and then re-install your yahoo messenger, if problem stay, check the other version of yahoo messenger.
By the way above, I think your problem will solve.
Other scenario:
Maybe you installed a software that make a conflict with your yahoo messenger and let it not to open, check that software! Remove the softwares that you installed these days.
Maybe your OS damaged, you know that if you run OS for too long times, it will dameged and you need to re-install it and fix the problems.So, if none of two ways above can't solve your problem, re-install your OS, but before that read the following note:
You can use some Optimize softwares for fix and make your OS optimize.like Symbian products.they could find the problem and fix them.So if this way couldn't help you either I suggest you to re-install the OS.
NOTE: Check your firewall, if you have firewall on your computer disable it and check runing the yahoo messenger maybe your firewall bothers your yahoo messenger!
Good luck
Mar 24, 2009 | Yahoo Messenger
Cannot install yahoo messenger 9.0.0.2128
Vista is the key as its looking for the administrator to complete the installation
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
Check
Feb 17, 2009 | Yahoo Messenger
I need experienced help to uninstall yahoo messenger will not unt
try installing it and then uninstall it !
if it doesn;t work than manually remove it (should be in Program Files\Yahoo\Messenger... i think ...)
Jan 07, 2009 | Yahoo Messenger
Yahoo Messenger Logo
21 people viewed this question
Top Yahoo Instant Messaging Experts
micky dee
Tony
Are you a Yahoo Instant Messaging Expert? Answer questions, earn points and help others
