Question about Canon NP 6050 Copier
No power hi, i have Canon Np 4050 there is no power what should i do please help me
    Scholar:
  • 62 Answers
Np4050 ? do they still make them? lol i still see them everyother day. wel if it doesnt turn on please check the breakers on the back of it. if they're ok then (assuming you electrical contact is ok) you are gonna have to check the PSU for which you are gonna need some electric knowledge. if you're up to it let me know. In other words, if the electrical supply is working correctly and the PS is getting the AC needed thne the problem is there, in the PS board. start by getting the multi-meter and check the fuses, contacts, the back of the board for sparking or damage.
Posted on Jan 22, 2009
How to canon np 4050 scanner lamp continuously on
It would be in service mode, why would you want to turn it On continuously??? Does the lamp turn ON with warm up? If so, the lamp and fuse is good. When you make a copy, will the lamp turn OFF and ON when it is scanning the original? If it dose, you will need to replace the scanner power cable. This copier is very, very, old.... I was trained on it over 20 years ago... Parts may be hard to find.... Good Luck
Dec 08, 2012 | Canon Copier Toner Cartridge Npg 4 For Np...
NP 4050 -
The door may be closed, but there is a inter lock switch that is not being closed. If you have all four paper tray, try to turn the copier off and disconnect the bottom two cassette's from the back of the copier and turn it back "ON" and see if the copier works. If it dose you have a problem with the bottom two tray's. You have a very old copier, can you do with out them? If not the switches are toward the front & it may just be knocked out of place... Good Luck...
Sep 17, 2009 | Canon NP 6050 Copier
NP 4050DRUM
Yield for Drum rated @ 120,000 copies. If you are asking for pricing....it depends on who you call for parts / service. Hope this helps
Aug 08, 2009 | Canon Office Equipment & Supplies
Can u tell me the load capacity of canon 4050
2.5 kva with 4 battrys any company
best for u.
Aug 04, 2009 | Canon NP 6050 Copier
I want to bye the model np 4050 i want known the price
I happen to have a NP 4050 for sale. Please contact me at yaucano1970@gmail.com. Thanks.
Feb 19, 2009 | Canon NP 6050 Copier
Canon NP 4050
I use this one
precisionroller.com
Oct 19, 2008 | Canon NP 6050 Copier
Cannon np 4050
The toner is not adding correctly into the developing assembly. 1) If toner hopper is overfilled, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) Sometimes the worm gear splits under normal use.
Jun 03, 2008 | Canon NP 6050 Copier
Canon np 4050 low fusing temperature
I am not 100 percent sure what is happening to your machine after it comes to ready, but I will offer some thoghts.
If it comes to ready and then goes back to a low heat situation. It very well could be the board if it doesnt maintain heat.
Now that being said, once a coiper comes to ready and reaches full heat, it will switch over to pulsating the heat roller, not staying on fully all the time. That is how fusers are designed. Full on until they reach operating temperature, then pulsating to maintain the rollers heat level.
If you are having a problem with the image not fusing to the paper, you may have an issue with the pressure roller not making good contact with the heat roller.
There may be a software setting that needs adjusted to increase the fuser operating temperature.
The flickering heat rod, once the machine reaches ready, seems appropriate.
If you want more of an idea, can you be more specific as to whether the machine is faulting out with an under heating situation, or is the image not fusing to the paper properly?
Dec 07, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
48 people viewed this question
old marine
old marine
