Question about Welding Tools
Wire diagram for a westing arc control box
Spool gun
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 24 Answers
SOURCE: The wire at the tip of the mig gun strikes an arc
Sounds like the trigger is getting worn out.
Posted on Apr 24, 2009
SOURCE: I PURCHASED A USED 185 MILLER SPOOL GUN..NEW IN
You will have to go to a dealer and get adaptor to unite spool gun & power source.
Posted on May 16, 2009
  • 225 Answers
SOURCE: wire broken off inside of liner in mig gun hose
about the only thing to do is take the gun of the unit ,place it straight in line on the floor or bench and try to hand feed the wire back the other way.good luck,this will be a lucky thing if it works.i dont understand how the wire broke off in the first place.
Posted on Aug 02, 2009
  • 8 Answers
SOURCE: Not sure how to connect the magnum sg spool gun
Needs to be in dcep, or reverse polarity to weld aluminum
Posted on Aug 12, 2009
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Lincoln sp-150 idealarc will not arc any more ground output checked ok fuses checked ok incoming power 230v ok output term for + voltage to wire on spool nopower when trigger pressed.continuity from
    There is a temperature activated switch near the transformer that will turn off control voltage until the transformer cools. There is also a fuse for the control voltage. That would explain why the motor won't run. There's a possibility that the trigger switch in the handle is bad too.
    Oct 15, 2014 | Welding Tools
    Spool won't turn
    are the rollers tightened enough, also maybe the wire is jammed in gun.
    Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
    I have a century 125 110 welder, the welding wire backs up to gun when stricking arc
    Hi there, Sounds like your wire speed is to slow or not feeding at all.Your wire may be crossed or the spool may be to tight.I lay mine on the side so the wheel shavings fall away from the wheels. and I open the lid to see whats going on.One time I got the wire twisted and It wouldn't work right and it finely snapped in to.Take the label off and that can help to.Feed some wire out with out striking an arc and watch the spool and rollers.Make sure wire is in the proper grove.One last thing you want to feel the wire push your hand back when you weld.Depending on the use you may need a new liner.Thank you for choosing FixYa.............Darryel
    Aug 08, 2011 | Century Welding Tools
    I have a 50A spoolgun and wc-24 controll box, but i cain't adjust the heat, and it is way to hot, any ideas as to what the problem may be. it worked fine one day and the next day it was too hot and...
    The control box for the spool gun it's just an adapter to feed the right voltage to the wire feed motor, the heat (voltage) must be adjusted from the three knobs:
    1) Process Contactor knob must be dial on wire feeder CV using remote.
    2) Polarity Must be set on DC
    3) Voltage, depends on thickness of your work piece and wire gage, but 20 volts must be enough for up to 1/4" thickness and 035 4043 aluminum.
    I never heard of a 50A spool gun, probably you meant 30A.
    If your voltage it's erratic check the following:
    Clean and tighten connections both inside and outside unit.
    Check and secure lead connections to remote control.
    Be sure connection to work piece is clean and tight.
    Remove excessive coils from weld cables.
    If continues to be too high (hot) and can't control it, then you should send your machine to be checked that's probably a problem with the PC1 or PC2.
    If this was useful to you please vote. Thank you and good luck.
    Feb 13, 2011 | Miller Trailblazer 302 Welder Generator...
    I have a spoolmate 200 ser. JJ373378 stock no. 084878 with a spool gun. i pull tricker wire runs no arc. I don't think main contacts are kicking in.
    If you wire runs, then your problem is the power line, check first that you have in hook up to the psotive (+) side of the power source/machine. The spool guns is just a wire feeder, your heat comes from the power source.
    Dec 30, 2010 | Welding Tools
    My fm140a will not feed wire
    You may need to adjust the tension just in front of the wire spool
    Your gun liner maybe shot
    Dec 28, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
    Apr 08, 2009 | Welding Tools
    Welding Tools Logo
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
