Question about EnGenius EUB-362 (EUB362 EXT) Wireless Adapter
EnGenius Mesh AP
Sir,
I config the Mesh Ap ..I will change the IP adderess also ...after i have enter new IP..but I forgot that Ip ..now I can't login .can u help me
Thank u
Ranju
  • 42 Answers
You will get a software which hacks the ip address search in google pls rate
Posted on Aug 22, 2009
Can't log in Engenius EAP-3660 .after rest factory settings.why? can you help me pls
You don't seem to understand what an Access Point is.
an AP is used to extend your wireless range and will connect to your routericon1.png to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
a router is an AP that will allow you to connect to your ISP for internet connection. A router can be configured to work as an AP but a AP cannot function as a router.
Read the manual. When you reset the AP the IP of the AP device became 192.168.1.1
That means you need to set the IP address of your computer to 192.168.1.x where x is anything from 253-2 and the subnet mask to 255.255.255.0
Feb 19, 2014 | EnGenius Computers & Internet
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
I followed all instructions and make all the right connections to my EnGenius M5000 AP to switch. The Internet Modem (from VSAT) is also connected to the switch including my Desktop standalone...
What IP is your Internet Modem using? If they use the same IP you'll have problems.
Your PC is connected wirelessly or directly via ethernet cable?
If you hare directly connected and you have your router set to enable DHCP, you should get an IP address. I assume you are familiar with networking enough since you know how to open command prompt and ping your router. Make sure that you get an ip (ipconfig). If not, make sure your cable is good and connected solidly and ensure DHCP is enabled on your router. If you are using static, just make sure the IP you assign to your desktop is in the same subnet. If you have a 255.255.255.0 subnet you can have 254 hosts on your network and they all have to be 192.168.1.X where X will change.
Apr 13, 2011 | EnGenius M5000 MESH Long Range Dual band...
How to configure the ap in mac os
First, make sure you disable the proxy if you`re using one, then open up your web browser and type in this address: 192.168.0.50. A login dialog will show up. The username:admin , left the password empty. Log in, and from there you can configure your AP. Good luck
Mar 16, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
Trying to connect Blackberry to EnGenius EOC Access Point - BB keeps saying it fails to get an IP address from the AP - how do I fix?
It sounds like your AP is not set up to be a DHCP server. If you want to use devices with your AP that expect to receive addresses over DHCP, then you either have to enable the DHCP server on your AP, or enable one somewhere else on your network to which your AP provides access.
Aug 06, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
Change the ip address
If your AP password erros, you can't enter the setup page of your AP in you browser. Do hard reset. Press little button behind your AP about 30 seconds. Will reset your AP to factory default, IP 192.168.0.50 subnet 255.255.255.0 user name: admin password: leave it blank.
May 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
AP edimax ew7209apg with core realtek 8186 gripped (bricked)
find the reset button. it will revert back the old ip hopefully.
Mar 31, 2008 | EnGenius EOC-3220 (EOC3220)
Please help! d-link airplus xg dwl 2100AP
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work.
Hope this Helps
Tech
CCNA, CCSP, MCSA
Mar 23, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
AP Mode Problems
Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
PHASE I
1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
(where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Phase II
1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
5) And lastly change the default user and password of your AP.
Good Luck
Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EUB-362 (EUB362 EXT) Wireless Adapter Logo
144 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
