How to stop noise from technics sl-j11 belt drive turnable
Annoying 'rubbing' wear noise when playing record (especially 33rpm which also seem to play 'slow')
djproaudio
  • 515 Answers
SOURCE: record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Posted on Apr 21, 2008
  • 11 Answers
SOURCE: Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Posted on Apr 13, 2009
  • 4234 Answers
SOURCE: How do you install the belt in a Technics LP SL-B300
assuming that you have the correct size belt, remove the platter and place the belt onto the platter (bottom side). Replace the platter and using a pencil, grab the belt and place it around the motor hub. The slot in the platter should give you enough room to do this. Dan
Posted on Jun 09, 2009
lesliemurphy
  • 69 Answers
SOURCE: technics sl-b303
Try this company for help?
service<remove>@turntableneedles.com
they have a help line and may be able to assist you?
Note; take the <remove> bit from the link to email them?
Posted on Oct 20, 2009
hondo73162
  • 132 Answers
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Posted on Nov 13, 2009
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Technics turntable model SL-bd27. center spindle rubbing noise.
hi, try to open or remove the platter on the deck, maybee there some small thing inside..
Apr 09, 2009 | Technics SL-1200M3D Turntable
Apr 07, 2009 | Technics SL-BD22 Turntable
Technics multiple play spindle wearing out it seems.
Need the model number. Technics released over 100 turntables between 1970-1990 - so a model number would help us in determining what you need.
- OPTiC
Repair Videos
Turntable Repair
DJ Equipment Sales
Technics Parts
Jan 03, 2009 | Technics SL-1200 Turntable
Technics SL-B2 not cooperating with R4450W Soundesign receiver
I would suspect that the receiver has only an AUX input. If that is the case, you will need to purchase a phono pre-amp. These are readily available for about $20 or so. This will boost the low signal level from the table to line level which is what the AUX input is expecting.
Dan
Nov 18, 2008 | Technics Audio Players & Recorders
Annoying sound
i forgot to mention,when i take the belt away from the mechanism that turns the deck,the scratch noise stops..
Jan 15, 2008 | Panasonic Technics SL-BD22D Turntable
82 people viewed this question
 Grubhead
Grubhead
