My top load kitchen aide washer kawe460w keeps getting out of balance and won't go they the spin cycle. What can I do?
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: How Old is Kitchen Aid Washer model#KAWE577BWH1
Your washer was manufactured in 1995 and is made by Whirlpool. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Posted on Jul 09, 2009
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Hallo,I have problem the cycle dosent spin kitchen-aid wash machine
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | KitchenAid KAWS850L Top Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
I have a Kitchen Aid clothes washer and the tub that you put clothes in won't stay centered. When it spins during the spin cycle, it gets out of balance and thump, thump, thumps............me and the...
there are 3 springs that hold it to the frame,remove the 2 screws from the washer head,one on each side,now pull up on the head and lift the front out and up,you will see 2 spring clips pop them out with a flat screw driver,open the lid and pull the washer case toward you,sit it aside and look at the other springs they will tell you where the other one goes,also the tub sits on a triangle bracket make sure that is in place to,under the tub,let me know-mike
Sep 26, 2008 | Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
