Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Can't take pictures
When I power up the camera, the lens extends, I get some flash images on the LCD as it boots up (including a brief view of what's seen through the lens), then the LCD goes blank. Of course, I can't take pictures with it in its present condition; however, I can view the pictures stored on the memory card on the LCD. When I power it off, the LCD reads usually reads "Retry Power On," and sometimes it says "Lens Error." Any suggestions?
    Genius:
  • 2,985 Answers
Casio Tech Support - especially if it is a young camera But repairs are not an economic option.
Posted on Jun 29, 2007
SOURCE:
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
What is it features ?
MPN Capture 1300 Key Features Resolution 1.3 Megapixel LCD Screen Size 1.5 in. Digital Zoom 2x Lens Interchangeable Lens Not Interchangeable Lenses Focus Type Fixed Focus Image Quality Image Sensor Type CMOS Camera Resolution 1.3 Megapixel Image Resolutions 640 x 480 • 320 x 240 • 176 x 144 Exposure Control Aperture Range f3 (w) Storage Memory Type CompactFlash Card Type I Built-in Memory Size 8 MB Compression Modes Fine • SuperFine • Normal Compression Type JPEG Flash Flash Type Built-In Flash Functions Flash Off • Auto Flash • Fill-in Flash Viewfinder / Display Viewfinder Optical LCD Screen With LCD Screen LCD Protected Position Without LCD Protected Position Interfaces Interface Type USB Power Supply Battery Type 4 x AA Batteries Included Features Built-in MP3 Player Unknown Built-in Microphone Without Built-in Microphone Built-in Speaker Without Built-in Speaker Tripod Mount With Tripod Mount System Requirements Operating System Microsoft Windows 2000 • Microsoft Windows 98 • Microsoft Windows ME • Microsoft Windows NT • Microsoft Windows XP Warranty Warranty 1 Year Miscellaneous Included Accessories 4 x AA Batteries • Software • USB Cable • Hand Strap UPC 647499779101
Mar 22, 2011 | Veo Capture 1300 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Canon S2 problems
Low battery power ? (rechargeables do not last forever).
Try a brand new set of batteries
Feb 06, 2008 | Canon PowerShot S2 IS Digital Camera
Screen white
if you are changing the lever to different positions...the green/edit, red viewfinder, or the red lcd view and get nothing...chances are your camera has the same problem mine does. The lever is broken and is not engaging the mechanism internally to change the views or power the lens to fully extend.
you won't be able to take pictures like me. I don't know if there is a fix or not. I guess the camera is prone to these problems as there are a few similar to what u describe with yours.
Dec 28, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Can't take a picture or even see an image in picture mode. I get an error message E18? I am able to look at photos taken in the past.
SkiPowder, the E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Guest has a different problem. Guest's problem sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Oct 31, 2007 | Canon PowerShot A70 Digital Camera
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
When i turn the camera to take a photo, no image appears in the LCD or the eyepiece. this just happened all the sudden. I am able to view pictures that I've already taken in the LCD and the LCD will also...
there may be two reasons for this problem. 1. may be a defective or broken CCD. 2. the shutter is not working may be due to broken flex circuit cable. in any of the case you have to get it fixed from a professional camera repairer
Aug 02, 2006 | Fuji FinePix S5000 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
103 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
