Question about Dishwashers
Dishwasher model LD-1415T1 the drain hose has split , can this be replaced and if so how much would it cost to repair
  • 116 Answers
SOURCE: Replacing a drain hose
If you remove the steel left side panel you can see that the drain hose only extends a short way into the machine. Where the hose enters the pan is a white clip that has a small square hole this clip can either be removed by pushing on it from the inside or prying the small square hole with a screwdriver. the drain hose is held in place by a black triangular clip on the plastic drain loop simply pull the clip off and slide the drain hose down then pull it out from the back of the machine.
Posted on Mar 11, 2007
SOURCE: LG Dishwasher Model LD-4120M Error 0E
LG 2050 error 0E error. - You may not want to believe this but it is true!!
My dishwasher has failed with 0E error 5 times now - it has cost me R350 each time - the problem IS NOT necessarily a blocked drain hose or the drain pump it could be the thermostat micro switch!!! the thermostat is located at the rear of the right bottom side of the dishwasher(held by oval nylon plastic housing). Turn the machine off. remove the right side panel.(remove top {2screws in lid at back}, remove right panel screws {2 behind door, 3 bottom back panel, 2 behind panel below door {pull panel out from top [no screws pushes in & out of place]}. Locate oval nylon/plastic shape located as above - micro-switch is in the middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1 each side of micro-switch). use screwdriver to push thermostat back into the nylon housing on both sides (it has worked its way out a bit over time and stops the micro-switch working). Reassemble and dishwasher starts to work again!!!!
Good Luck - Alan
Posted on Oct 31, 2009
rylee_smith
  • 8619 Answers
SOURCE: my LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 08, 2009
Testimonial: "well done"
  • 115 Answers
SOURCE: How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Posted on Dec 13, 2009
Macmarkus
  • 2605 Answers
SOURCE: the dishwasher does not drain, i just replace my
Hello, Welcome to FixYa. I just came accross your post and immediately I thought, " drain plug in garb not punched out" this is very common when a new garb or dishwasher is installed..so much If I had a dollar for every one I saw or heard about I could be paid a couple of trip charges. If you haven't already done so, remove the drain hose from the garb and knock out the stop inside the spout. See your installation guide/owners manual ( for the garb/disposer ) if you still have it, that should show you "where" and "how". Let me know either way and I'll help further if necessary. Regards, Macmarkus :)
Posted on Feb 22, 2011
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
What does OE code mean on LG LD-1415T1 Dishwasher
a draining problem either the drain hose is kinked or blocked or the pump impeller is jammed with something so its not turning or a bad pump good luck
Dec 15, 2013 | LG Dishwashers
Hi i have an LG dishwasher ld 1415T1 it has started leaking water at the front bottom. the rubber seal looks ok and clean any ideas Bryan
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
please check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3/1292/how-to-replace-a-leaky-dishwasher-door-seal-h.html
Jul 29, 2011 | Dishwashers
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
My LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks
Rylee
Nov 08, 2009 | LG 24 in. LD-12BW5 Free-standing...
I keep getting an E1 error on my LG LD-2120W model dishwasher, can you advise what this means so l can either fix it or get it fixed. Thank you
leakage Error E1
  • The excessive RPM of Washing Motor happened during Washcycle due to water leakage.
  • Water leakage in Hose connections.
  • Water is leaked by damages.
  • The Motor Water Seal leakage of Sump assembly.
  • The height of Drain Hose connection
  • (sink-Drain Hose) is not over 20 .
  • Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
fix it to the recommended Height. Replace the Impeller of the Washing Pump.
Sep 27, 2009 | LG Dishwashers
Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Aug 30, 2009 | LG Dishwashers
Hi. this may be caused be several issue that i will discus below. Kindly read over the list that will describe several issue that may be apparent. replace any parts that corresponds to the issue you are having.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Model LD-14AW2 alarms after 1 minute of startup and says E1
The E1 error is telling you that there is a leak in the dishwasher. After confirming that there is no leak, even directly under the dishwasher (remove the kickplate and use a flashlight.)
After ruling that out, your problem is almost certainly caused by the drain hose between your dishwasher and your drain. There MUST be a 30" rise in the drain hose between the DW and the drain. If the hose just lays there, causing a siphoning effect (law of physics) that WILL drain water out of the dishwasher into the drain as soon as a wash or rinse cycle begins (after 1 - 2 minutes after they begin. Then the E1 error will be displayed.
The BEST way to fix this problem is to install an AirGap valve (almost free @ any hardware store) in your counter/sink and then running the short pipe to your disposal or sing drain inlet. If that is not possible or for a quick and dirty repair until you can install the AirGap, tie the drain hose to the bottom of the counter top so the rise is created.
Good Luck!
Apr 02, 2009 | LG Dishwashers
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
