Question about HP Compaq Evo Notebook N620c
Trying to set up a home network
Have a COMPAQ Evo N620c that won't work with a wireless router and a NetGear wireless antenna. What do I need to do to gain Internet access on this laptop. Set-up was done properly and even showed connectivity had occured.
Drivers problem for compaq NOTBOOK Evo N620c
download from here
Jul 02, 2010 | Compaq Evo N610C Notebook
Just an installed Windows Vista on an old Compaq N620 EVO laptop, but now I can not find a compatible driver for the Wireless LAN Multiport W200. Everything else works fine, but can't connect to the...
Hi. I've been trying to search for driver for your Wireless LAN and i beleive there is no available driver for this device. Even HP doesnt have available driver in their website. Please click here.
Jun 13, 2010 | HP Compaq Evo n620c Notebook
Internet connection not working right compaq evo n1020v
First you will need to have the install disc for your card.Install driversoftware from cd or dvd, following directions.Once installed you should see a new hardware device has been found notification.
Next you will need to configure your card with the routers wep key or wireless security key.I am assuming wireless is activated on your router.Should see a light on the router lit under wireless,or a symbol.
1 start pc then start internet explorer.
2 Type in the top bar of ie or hit enter.
3 This should bring you to the routers home page.usaername=admin password=password or admin
4 Find your wireless tab or settings page looking for security area.
5 Find your wep or wireless security code,write this down.
6 Log off of router.
7 Go into network cards configuration program and put this wep code into the area provided.
8 Software may have found it automaticly, it just needs this code.
If you cant connect to router at step one use a ethernet cable from your pc to the router to log on.
Hope this helps.
Jan 23, 2010 | Compaq Evo N1020V Notebook
Wireless software
if xp use this :
Jun 12, 2009 | HP Compaq Evo Notebook N620c
Cant connect wireless
If the stick is the solution, why are you avoiding the solution?
From what you have said, the internal wifi in the Evo doesn't work, while
an external usb stick does.
Assuming that your internal wifi is properly configured and functional, it is
incapable of picking up your home wifi signal, though it might be functional in other situations ... Buying an external usb stick gives you a better antenna position and takes nothing away from your system, while adding functionality and sheilding the innards of your system from viral
attack as a first line of attack that is detachable.
Buy the USB stick.
Apr 14, 2009 | Compaq Evo N600c Notebook
Internet access and home network
if u mean to say that u r not able to connect to internet with ur wireless adapte, even if the connectivity is shown, then its nothin difficult to solve..
Look, this sometimes happen just due to Drivers that conflict with each other & ultimately, the svchost of ur computer freezes.. Thus, no connection is allowed to transfer any data..
simply follow the instructions
go to properties of my computer
go to device manager
now select the network adapters and expand the tab
now select ur preferred adapter, which u consider to be not working
now select it & make a right click over it
now select uninstall
dont worry, it will just remove the device from ur computer & make sure u dont remove the drivers of it
now after inonstalling, if ur computer automatically detects a new hardware, then its k, else restart ur machine,,,,,
as u restart, a pop up will occur named "NEW HARDWARE FOUND"
let the machine do its job and after it installs everything, again restart ur machine & thats it
If it worked then its k, else i'll love to hear more about the problem..
If u like my post, please rate me up, i really want some good ratings..
Jan 20, 2009 | HP Compaq Evo Notebook N620c
Netgear 624
to set upa network
there is no "earthnet" connection. it is an ethernet connection. it looks like a phone cable but has larger ends than a phone connector. the router is connected to the computer via an ethernet cable if it needs to be hardwired to a ethernet port or internal ethernet card. a wireless connection only needs to be an add-on internal card w/antenna or a usb connector hub (it looks like a usb flash memory stick)
here is how it's done. netgear has the same type setup.
Oct 13, 2008 | NetGear WGT624 Wireless Router
Compaq evo n610c
You need a PCMCIA Wireless adaptor, (this model you are getting has two slots that it will fit in) - and you must make sure you have a wireless router in your house to broadcast a wireless signal for it to recieve.
Mar 28, 2008 | Compaq Evo N610C Notebook
Compaq evo N620c
Go to Start/Run.. Type cmd in the box and hit enter.. (Command prompt) box shows, Type: ipconfig/release hit enter.(Should show Zeros for adapter). Type ipconfig/renew and enter again see if it detects and works..
Let us know..
(Are you a secured or at least a WEP enabled network)?
Feb 06, 2008 | Compaq Evo N610C Notebook
HP Compaq Evo Notebook N620c Logo
104 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
