The Number key in my laptop overlap over the letter key.
How do I use the the number key? It is overlapped over the the letter key. Can you help me with this?
THANK YOU
Try pressing the FN key at the same time as the number key.
The FN is a modifier key and when pushed the same time as another key, it changes what the button does usually. Many of these alternate functions can be found on the F buttons along the top of the keyboard.
Posted on Jan 20, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
Valve overlap
Firing order determines what is next.Follow the firing order.I know when finding compression stroke on v8 when 1 is at tdc 8 is on the rock.Cleveland v8s firing order is 18436572.
Oct 20, 2008 | 2000 Audi A6
OVERLAPPING INSTEAD OF INSERTING.
Even in Microsoft Word, you can choose if you want to insert or overwrite. You do it by pressing the INS key on the keyboad. As you do not reveal the identity of your calculator I can only provide a general solution.
If the keypad has a marking Ins about a key , you use it to insert either directly by pressing the key or as a Second/Shift function. Once toggled the Insert/Overwrite mode should persist until you toggle it to the other mode.
It is also possible that your CAS can be configured for the Insert/Overwite setting.
Hope it helps.
Nov 08, 2009 | Texas Instruments Office Equipment &...
Is it UHF or VHF
This is a UHF radio.
SDC is 450-520 MHz.
RDC is 403-470 MHz.
As you can see the two bandsplits overlap in the common 450-470 MHz range. If your frequency is between these numbers either of the HT1000 models will work for you.
FYI: VHF has the letters KDC usually.
Jul 28, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
When typing does not print whole letter or doesn't print at all.
it would help if i knew exactly what model # we are talking about. but try this. look closely at your ribbon film after you type some characters. are the letters overlapping themselves? if so, press and hold the "code" key down while pressing the period key. let up and try typing. if that doesn't help, write back with model # and maybe i can assist further.
razors
Mar 30, 2009 | Swintec Office Equipment & Supplies
Gapping/overlapping of letters
Its sounds like tou may need a rotate adjustment. Take it in for service.
DickyO
Sep 10, 2008 | Office Equipment & Supplies
Some letters are locked
From the question I can assume that you are using a laptop computer. The reason that his happens is because you have hit Num Lock thus enabling the numerical terms in place of your alphabetic ones. The reason that they overlap the keys is that laptops are compact and cannot hold their own number pad, so they simply make it a toggle on/off thing for people who like using the pad version rather than the lengthwise one above the normal letter keys. Hope this helps!
Jul 25, 2008 | Computers & Internet
Swintec 7040
Look for a slide showing 10,12,and 15 select 10. to bold hold down the code key and press the bold key. to capatlize hold down the shift key.
Jan 10, 2008 | Swintec 7040 Typewriter
Letter sized fax page overlaps onto 2nd page
Change your faxes DEFAULT font size to a lower setting... lt us know if it still does the same thing for the same amount of characters
Nov 09, 2007 | HP PSC 1510 All-In-One InkJet Printer
Computers & Internet Logo
449 people viewed this question
David Payne
David Payne
