Onkyo TX-DS575 Receiver Logo
Anonymous Posted on Jun 29, 2007
Remote stopped working
Remote started working intermittently. reset with v1 & speaker a trick revived for a few seconds then stopped working again. will check with another remote but any other suggestions?
Sunil Karickom
Level 1:
Habit-Forming:
  • Contributor 45 Answers
  • Posted on Jun 29, 2007
Sunil Karickom
Contributor
Level 1:
Habit-Forming:
Answers
45
Questions
0
Helped
15124
Points
93
It may be due to dry soldering of the crystal if u have a radio switch on it in AM and press the remote button u can hear tones in the radio if not hearing the remote is not working and replace the crystal and check
Samsung AQ12FAN, indoor unit starts on it's own, and stops after a few seconds, and starts again, and stops again, and... All this even with the batteries out of the remote. If I turn on the unit, after a...
It could be that the motor for the device needs to "warm up". Everytime it stops the internal thermostat sees that the target temperature has not been reached so it starts the internal motor again. This happens in a cycle until the motor gets warmed up or the target temperature is reached. This is my hypothesis. So, you might need to get the devices's motor checked out. Thank you.
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Chamberlain 1/2 hp opener stops intermittently during travel.
could be that the remote operation or cycle operation needs reprogramming as it indicates that the program has a corruption in it and the action is lost by that corruption
follow the user manual and do the reprogram sequence
My remote control stops working every few months or so, then starts working again. My warranty goes out this month. Just have a service call and the tech left me another remote, but I'm afraid this will...
The remote interface of the TV died on mine, it was intermittent then it stopped completely. Remote control is fine, it's the remote sensor in the TV itself.
My speaker is not working and few seconds later, it works again
the sound card is using other type of modem while the IRQ and DMA is using the same system so that your speaker or audio will not work properly!
Anti-theft has engaged
sounds like the transmitter in the key head is defective or it lost programming, try these programing steps, if that doesn't do it u need another key made.
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door
locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm
programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to
confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
