Question about Microsoft Windows XP Home Edition
Iso image of original xp-3
Send the complete path or iso image of xp-3
  • 184 Answers
Http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&DisplayLang=en
Posted on Jan 20, 2009
There I can download windows xp iso
Microsoft won't allow any ISO images to be downloaded unless you are a Microsoft partner/solution provider.
The alternative you will have to resort to the torrent downloads. just be careful, because a lot of stuff on the torrents are infected with viruses.
Try a local IT shop to assist you with an image, if you ask them nicely they might help you.
I suggest to buy legal Microsoft software or use open source software such as Ubuntu Linux if you can't afford it.
Apr 02, 2014 | Microsoft Windows XP Professional
The link given above is a download of Service Pack 3 only,not for the XP Operating System itself.Microsoft no longer supports XP and there are no LEGAL downloads available.
You can use a disk that belongs to someone else,but that's not exactly legal either.
Microsoft recommends that you buy a new copy of the OS.
Sorry about that.
WIN XP HOME.TELL ME THAT IM MISSING NTLDR?
You may need to do windows repair or clean install by using following steps:
In case you dont have a disk you can install windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start booting from USB).
Step 8- follow the on screen instructions to complete the windows installation. Thanks
Oct 28, 2013 | Computers & Internet
Error 0x80070057
You can use your original Windows 7 Ultimate installation DVD as a Recovery Disk if you have one, alternatively, you can download a copy of an official Microsoft Windows 7 Ultimate 64bit DVD .ISO disk image from the following URL.
http://msft.digitalrivercontent.net/win/X17-24395.iso
Note: The above download image is 3GB in size and may take some time to complete depending on the speed of your internet connection.
For those looking for download links for other versions of Windows 7 these links were published on the AskVG web site a little while back and include .ISO images inntegrated with Service Pack 1.
If you are having problems when burning an ISO image to DVD media that is giving the 0x80070057 error, then you may have a device driver issue as that seems to be a common cause of such errors.
You could try using a free third-party CD/DVD burning utility such as CDBurnerXP which works fine on Windows 7, Vista or XP.
Dec 24, 2011 | Microsoft Windows 7 Ultimate for PC
How to create a bootable Windows XP SP1 CD
Using nero .
Step 1
Create 3 folders - C:\WINXPSP1, C:\SP1106 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP1
Step 3
You will have to download the SP1 Update, which is 133MB.
Rename the Service Pack file to XP-SP1.EXE
Extract the Service Pack from the Run Dialog using the command:
C:\XP-SP1.EXE -U -X:C:\SP1106
Step 4
Open Start/Run... and type the command:
C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP1 contains: Windows XP SP1
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip
Code:
Code:
http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.
Select File > New... from the menu.
1.) Select CD-ROM (Boot)
2.) Select Image file from Source of boot image data
3.) Set Kind of emulation: to No Emulation
4.) Set Load segment of sectors (hex!): to 07C0
5.) Set Number of loaded sectors: to 4
6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:
Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab
Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)
Set Format to Mode 1
Set Character Set to ISO 9660
Check all Relax ISO Restrictions
Step 5
Click Label Tab
Select ISO9660 from the drop down box.
Enter the Volume Label as WB2PFRE_EN
Enter the System Identifier as WB2PFRE_EN
Enter the Volume Set as WB2PFRE_EN
Enter the Publisher as MICROSOFT CORPORATION
Enter the Data Preparer as MICROSOFT CORPORATION
Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN
* For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab
Check Write
Check Finalize CD (No further writing possible!)
Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP1
Select everything in the folder and drag it to the ISO compilation panel.
Click the Write CD Dialog button.
Oct 11, 2010 | Microsoft Computers & Internet
Plz send me full form of windows xp
http://www.tipandtrick.net/2008/windows-xp-sp3-with-service-pack-3-full-installation-cd-iso-image-relased-on-msdntechnet/
Aug 21, 2010 | Computers & Internet
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Jun 01, 2010 | Microsoft Windows XP Home Edition
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
112 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
