Question about ASUS P5KPL-AM SE Motherboard
I check the fan and it's ok but still won't work
  • ASUS Master
  • 3,606 Answers
Hello you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLAM/#download
By selecting your windows system.
Open the manual folder and click on global for download.
Your mainboard is a socket 775, and the fan could be blocked if the cooling element is not fitted correctly.
You are probably useing the most common fan/cooling element :
This fan is a piece of sh..
My advice is to buy a better fan/cooling element online for better cooling capabilities.
You can buy this online, or in a computer shop.
The fan must be connected to the 3 pin connector CPU_FAN not the SYS_FAN on the mainboard, so the bios can control the speed, when it gets hot.
Always remember to renew the thermal cooling paste, when remowing the cpu fan.
Good luck
Posted on Jan 07, 2013
Help me
Ok, If you go to your thermostat and turn the fan switch to ON from AUTO, does the fan operate?
If so you have proven you have both high and low voltage, saving you the need to check breakers, fuses etc.
If they are good check on your circuit board in your furnace for a 3 amp automotive type fuse, it may be blown, if no fuse equipped the transformer may need to be tested with a voltmeter.
Jun 28, 2013 | Heating & Cooling
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
MY RADIATOR FANS WON'T WORK
check wires to tempature censer, follow wires from fan to censor if there ok replace the censor, be sure to disconnect the battery first.
Sep 07, 2012 | 1989 Nissan Stanza
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
I have a 1996 town & country 3.8L. I replaced the
You need the system scanned for codes, the fans and controlled by the engine computer.
Jun 16, 2012 | Cars & Trucks
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
1985 new yorker cooling fan won't operate.
could be a bad coolant tempurature sensor if radiater cooling fan does not work, or a bad relay for fan in fuse box for the fan.. if all is ok ! disconnect fan at the connectors. on the motor side, run a wire from positive on battery, to pos itive fan motor. ground other wire to negative on battery. if the fan works its ok. good-day ! check relay and fuse for the fan first.
Feb 01, 2012 | Dodge Vehicle Parts & Accessories
Hi, Vulcan " burwood " gas space heater.I have
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
May 19, 2011 | Heating & Cooling
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
ASUS P5KPL-AM SE Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
