Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
I have a Dell desktop. My montor won't turn off. When I turn off the computer, the light on the monitor remains green and then it starts to change color repeatedly-from red to blue to white, etc.
    Novelist:
    Champion:
  • 233 Answers
If it works fine otherwise I don't see a problem here. If these lights bother you just turn off the monitor.
Posted on Jan 20, 2009
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
I just have a OPTIPLEX SX280 and try to connect to my old montor (VGA), when I turn on power it seem run starting but the it show up on monitor screen "can not display video mode". What is that...
When you first power on the computer tap the <F8> key to bring you to a menu that has the option of running in safe mode. If the computer boots up in safe mode and you are able to see the display on your monitor then your current video drivers are not supported for the old monitor.
Sep 10, 2011 | Dell OptiPlex SX280 PC Desktop
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
Ok when i turn on my aoc monitor colors like blue green red white pop up i can never use my desktop
I would suggest that you try another monitor. If the monitor continues to light up with these colors and you do not see your computer desktop, then I would tend to think that your computer may have a problem with the video card or driver. Do you get a message on your montor with words like "no connection" or "No signal". If so, this means that the monitor is getting no video signal from you desktop. Try disconnecting your monitor plug and removing power from the monitor in an attempt to reset the monitor. Try also to turn off and unplug your computer. Leave the computer unplugged for about 10 minutes and start it up again. This may reset your computer. If you monitor video cable will disconnect from the monitor, you may want to get a new cable. These cable do go bad sometimes and are available and inexpensive on Ebay.com
Try these ideas and let me know how you do.
If you found this answer helpful, please remember to leave positive feedback. If you need more assistance, let me know.
Thank You,
Brian
Mar 20, 2011 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
Feb 06, 2009 | Dell Dimension 2400 PC Desktop
Monitor won't turn off
Monitor will be like that until it is powered off. Only when it is powered off, the light goes off and there will be nothing on display.
Jan 20, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
My monitor will not turn on
disconnect the monitor cable from your computer tower
if you get a 4 colored box which says power on self test. it means its not the monitor then you have to get the video card or the systemboard.
Jun 09, 2008 | Dell P793 17" CRT Monitor
Acer Monitor will not function
Monitor is getting hot and cutting off. Try on another computer. Try another video card. If it does the same thing then it is BAD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
48 people viewed this question
Alun Cox
