Question about Bodum Bistro Electric Burr Coffee Grinder White
Bodum bistro grinds too fine - Bodum Bistro Electric Burr Coffee Grinder White
2 Suggested Answers
SOURCE: Am considering buying a Bodum
It,s conical. It can be easely remowed for cleaning. Just take it easy so you know how to put the pieces back again. Its a very good priceworthy grinder. I still use mine after 15 years. But as it comes from the factory it will not grind fine enough for espresso. There are various methods and instructions on the internet how to tweak them to grind finer if you want that. Internally the mechanism looks very similar to the Solis and Dualit grinder. Since my grinder i quite old i dont know if my tweaks will work on more modern machines. But the basic construktion i still the same.
Posted on Feb 12, 2011
How can i get manual for model 10903?
Do you mean the Bodum Bistro electric coffee grinder 10903? The instructions for use are available on the product page: http://www.bodum.com/us/en-us/shop/detail/10903-01US/ . Look on the right hand side of the page. The direct link to the manual is http://www.bodum.com/media/ifu/10903-01US.pdf . See page 4-5 (7-8 of the PDF) for the directions for grinding. The cleaning directions are on page 6 (page 9 of the PDF).
I hope this helps.
May 11, 2016 | Coffee Makers & Espresso Machines
Water does not heat
PDF]Instructions for use (PDF) - Bodum
www.bodum.com/media/ifu/11001-01EURO.pdf
BodumCongratulations! You are the proud owner of a BISTRO pour over coffee machine fromBODUM®. Read through these instructions carefully before you use the
Aug 30, 2015 | Bodum Bistro Coffee Makers & Espresso...
How to fix a bodum bistro electric coffee grinder that doesn't grind well
This can be caused by several things;
If it used to be good but is now faulty it is most likely that it just needs cleaning. If you are using beans that are 'oily' they can clog the grinder, you should anyway disassemble it and clean every year. Do not use soap and water, just brush it with a stiff brush (e.g. the stiffest type of toothbrush) and a vacuum cleaner.
There is also a possibility that something has got into the grinder along with the coffee beans that has damaged the grinding wheels; in that case you need to replace the wheels.
Jul 29, 2014 | Bodum Bistro Electric Burr Grinder for...
Green light goes ON but nothing happens
I have the same problem after using it only twice...the store won't take it back as they no longer carry them, and there is no place local to repair them...and I can find nothing online to fix it. it was too expensive of a machine to have this kind of problem that is not easily repairable.
May 07, 2014 | Bodum Bistro b.over Coffee Brewer - Black
How do I fill with pepper
On most pepper mills, some part of the upper half usually unscrews, and the 'top' and 'bottom' can be separated. The bottom part will have a 'reservoir' in which the peppercorns should be placed, to eventually be ground.
Apr 05, 2014 | Bodum The Furniture Store Bistro Automatic...
My element has burnt out
I love my Bistro toaster but it will only heat on one side,
is it repairable?
Feb 10, 2014 | Bodum Bistro Toaster
Myu Bodum Bistro burr grinder calibration is off. How do I fix it?
Did you ever find a solution? I have the same grinder and it is off as well now after taking it apart.
Nov 11, 2012 | Coffee Makers & Espresso Machines
Am considering buying a Bodum Bistro grinder. Need to know if the burr grinder is conical and whether or not the inside cone can be removed for cleaning
Jan 31, 2011 | Bodum Coffee Makers & Espresso Machines
Can't reassemble shin bistro after purchasing replacement beaker. the screw that holds the metal "strap" around the beaker wont screw in properly.
You must have misplaced the small metal square piece with a hole in it that the screw should mate with.
Jan 08, 2011 | Bodum Shin Bistro
Bodum Bistro Electric Burr Coffee Grinder White Logo
55 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Peter Meixler
Peter Meixler
Level 1 Expert
CrisO
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
