Question about Neff U1721 Double circotherm Electric Oven
How to set the timer
Unfortunately, I have lost the instruction maual and cannot work out how to to set the timer on this oven. Can anyone help
  • 8,197 Answers
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Posted on Jan 20, 2009
Stove works but not oven
You should be able to find the users manual at this site:
http://www.fisherpaykel.com/us/support/
Mar 19, 2014 | Ovens
Homeking oven hof605ss
Try turning off the circuit for a minute, then set timer again.
Often a little picture/icon of a "baking tray with heat" when timer is passing power on to the thermostat.
Also, those timers fail often enough, is the oven brand new (or recent blackout)?
Oct 17, 2013 | Ovens
I have an oven dop740X I cannot rest the controls. The timer and lock are on and I dont not have the maual?
Try turning off the oven at the main fuse box, remove the fuse/circuit breaker for 10 mins, insert the fuse/circuit breaker. This may reset the oven and you need to set up the time again.
Nov 19, 2011 | Ovens
Oven not heating
If it has a digital timer, make sure it is set to auto and not manual, as oven will not heat if it is on auto.
If it is a anolgue timer ,then it should be showing a hand symbol,if it is not, then turn knob or dial until it does.
If these settings are o/k, then could be a faulty element.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Ovens
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Oven timer
We bought an older home with an electric Amana oven. Problem is, the timer on the oven goes off whenever it wants to. Usually, during the night! How do we stop this besides unplugging the thing every night?
Jul 05, 2008 | Ovens
Smegg Oven Model Number and problems ... please help =)
It looks like an S551X-5, I think the timer is a safety mechanism, maybe just set it to full when in use and turn it off when you finish.
Go to http://www.smeguk.com/KitchenStudioLine/Product/S551X-5.aspx to see features, etc.
Jan 28, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Neff U1721 Double circotherm Electric Oven Logo
659 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
