Question about Directed Electronics 5103L Avistart 5103 1way Alarmremote Start D2d
Avital 2101 installation wiring manual - Directed Electronics 5103L Avistart 5103 1way Alarmremote Start D2d
Will avital 5303 work with a 2010 prius
It should go to this site http://www.the12volt.com/installbay/forum_posts.asp?TID=52897 it shows your Pirus if you go under the tab vehicle wireing, manufacture, model.
Apr 07, 2014 | Avital Vehicle Parts & Accessories
Detailed wiring info????
Hello Tom,
Power lock gray (- polarity) at white plug near fuse box.
Power unlock (- polarity) purple, at white plug near fuse box.
These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.
Mar 24, 2014 | 2101L Keyless Entry System
Tach and speedo quit working after remote start installed. My 04 yukon's speedo and tach will quit working. I can unplug battery for 5 minutes and will work for a few days. If I turn off vehical o
Well, if you connected the tach sense wire (violet/white) from the Avital, remove it and use either virtual tach or voltage. It sounds to me that whatever you have connected to the tachometer is sending a signal rather than sensing, causing the malfunction.
Jan 20, 2013 | 4103LX Remote Start System with Two...
Need wire diagram for avital 5103
You can download a copy of the installation manual from this link:
Avital 5103 installation manual
Sep 24, 2012 | Directed Electronics 5103L Avistart 5103...
Avital 2100 wont let me program 473 L remote
is the door open? door trigger switch has to be installed either green or violet wire the blue instant switch doesn't work as a valid trigger
May 10, 2012 | 821001/2100 2100 Security System
I lost my remotes for my remote start 4103. I have an unused keyless entry model 2101. Does anyone know if the remotes are interchangeable so that I can have the new ones programmed to operate my remote...
It is not likely that they could be used interchangably. The reason is the narrow radio spectrum that is used and the desire for such companies to produce proprietary pieces.
It is is possible if you were to get a Fob for a 4103 off Ebay for example, they could be resynched. But the remote start is going to have a different signal than the remote door lock. just so they can be operated independent of each other. So it is not likely the 2101 would do more than sync to the door locks.
Feb 18, 2012 | Remote Start with Two 4Button Remotes ...
My avital 4103 does not unlock the passenger door when unlocking OR set the alarm when locking - should it?
Its not the avital piece that's the problem, it's your INSTALLER that is/was the problem....haha, got somethin wired wrong!! It only does what you install it to do! :)
Dec 11, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Hello. I have an Avital 4103 system and the key light on the dash does not go out after starting the car, inserting the ignition key and turning. I can drive the car, but the key light keeps flashing and...
I have a Dodge Caravan 2001 SE. Had the Avital 4103 installed. My question is, before installation i had a Chrysler car alarm in the van. When the remote start was installed they removed the alarm.
The shut down toggle switch was not installed, also the push button valet switch was not installed also. Is this a correct installation, I was told that I did not need the last two items to be installed.
Oct 27, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Directed Electronics 5103L Avistart 5103 1way Alarmremote Start D2d Logo
133 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
