Question about ASUS K53sd 15.6 Inch Laptop Intel Core I7 2670Qm 2.2Ghz, 4Gb Ram, 750Gb Hdd, Dvdsmdl, Lan, Wlan, Webcam, Windows 7 Home Premium 64-Bit
Not power on
Adapter power out put is ok. but laptop power cable connect not power on ?
    Novelist:
    Champion:
  • 233 Answers
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and asus k53 ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
Posted on Jan 07, 2013
Inspiron 5547 will not turn on
Ok first of all is the laptop getting any power?Does anything light up? are any of the caps,scroll or numlock lit up ?flashing?
if not then remove battery and only connect the power adapter. Power laptop on. Anything? Jiggle power adapter cable to see if thier is a break in the cable.Jiggle the connection from where the power adapter connect to the laptop. Could be the DC jack /power cable
Go to this link for further instructions
How to Resolve No Power No POST No Boot or No Video Issues with Your...
Aug 02, 2014 | Dell Computers & Internet
Check cable connection acer 4739
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 23, 2013 | Acer Aspire 5500 5570-2609 Laptop
How can i resolve a pc that does start
Feb 26, 2013 | Toshiba Computers & Internet
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
The battery cannot charge after connecting to a power source
Take out of your battery, then plug in your ac adapter, see if it works, if no, then you have a faulty ac adapter, you need to replace it; and if yes, then you adapter is ok, the battery or dc jack may be broken.
Jun 01, 2011 | Lenovo IdeaPad Y450 20020 Laptop AC Power...
Ibm thinkpad R52 laptop no powering on, adapter is ok.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 26, 2009 | IBM Lenovo ThinkPad R52 Motherboard -...
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
Put in a branbd new battery. Power adapter is OK.
Your motherboard does not need replacing provided the problem is the power socket on the motherboard.
If the power adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 15, 2009 | Compaq Presario 3045US Notebook
My dell inspiron 1525 wont switch on, no lights or sound at all please help!
The first thing to try is a different AC adapter. About half of all no power failures are the AC adapter no longer sends power to the system. You can also use a multimeter to check the DC output of the adapter (About 20VDC) If the AC adapter is putting out power or a known good adapter doesn't make any difference, then try reseating the LCD hinge cover cable connection. If still no power and especially if the power jack seems to be damaged, then a motherboard replacement or adapter jack replacement is required (Roughly $100 either way)
Nov 13, 2009 | Dell Computers & Internet
There is no response at all when I try to power up. I was told it is the motherboard however I have only owned the computer for 15 months and it is no longer under warranty.
Check first if you have a green light on your power adapter, If yes your power adapter is good, maybe your output cable of adapter is broken, If not, You power connector on you laptop is broken. If you laptop recieve a charge light , for sure your adapter is ok. In order to verify your motherboards is ok, remove your ram, hdd. Put back the ram and try to power On the laptop, If still no luck, the power mosfet location at the end of motherboard need to replace. Bring your laptop to expert technician.
Jul 23, 2009 | Dell Inspiron 1420 Notebook
ASUS K53sd 15.6 Inch Laptop Intel Core I7 2670Qm 2.2Ghz, 4Gb Ram, 750Gb Hdd, Dvdsmdl, Lan, Wlan, Webcam, Windows 7 Home Premium 64-Bit Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
