Question about Microsoft HP Pavilion DV6276US Notebook PC
Where is the cd eject button??
We went to computer and could not find eject
and please tell me where the search files and folders button is
thank you !! =^^=
  • 404 Answers
Hello!
There should be a small oblong button on the cd tray by lightly pressing it the device should open.
For file search, click on start and above it should be search.
Hope this helps,
Please remember to leave comment for my effort.
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Posted on Jan 20, 2009
How to eject a cd
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVDicon1.png drives in all macs are a bit suspect and if your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge. Hope this helps.
Apr 30, 2013 | Apple MacBook Pro Laptop Computer with...
Tip
CD Insert Without pushing a button!
This will not work with a Laptop drive unless it is the slot loading type.
We already have 'Eject' when we right click the CD/DVD drive from (My Computer), which ejects the drive tray. But to insert the tray inside,we have to manually push the insert button on CD/DVD drive.
Another way most PC owners insert that CD tray is by pushing the tray itself. I'm sure nobody mentioned this when you got that PC, but that push to insert feature (Also called the bump feed) is not really safe to use over time. If you happen to say, push too hard because you are in a hurry, the gear which pulls your CD tray in can skip a tooth, making that CD or DVD open and close all by itself, or even worse, making it stay locked tight forever.
Here is a trick that allows you to insert the drive tray without actually touching that button. Simply by putting the 'Insert' sub-context(as shown in above figure) menu on the CD/DVD drives Context menu. For this to happen, we need to use a dll file from our windowssystem32 folder.
First of all, download this file CDEject.zip and extract it. There will be two files CDeject.dll and CDeject.reg. Now follow the step by step procedures.
1. CDeject.dll -> copy this file to X:windowssystem32 folder (here X is your corresponding drive letter, usually it's drive C:)
2. CDeject.reg -> execute it. It shows a warning message, accept that and click OK.
Now try right clicking your CD or DVD drive and click eject, then right click again and choose insert.
Amazingly cool isn't it?
So far I haven't found a way to make the CD hop in the tray all by itself, but I am still hopeful.
And you thought you couldn't program!
Have fun with that!
Please Vote for this Tip if you found it helpful.
Bob S.
on Apr 02, 2010 | Computers & Internet
IN FEW DAYS I SEE THAT SUDDENLY THIS CD/DVD DRIVIE IS LOST MY COMPUTER.WHEN I RESTORE MY SYSTEM IT WILL BE COME BACK ITS WON POSITION.THIS EVENT OCCUR 4 TIMES WITH MY COMPUTER.WHAT CAN I DO FOR THIS? AND...
From the problem description I understand that the CD/DVD Drive is not visible in the Computer window. Also, I would suggest that check in Device Manager if the CD/DVD Drive shows yellow exclamation mark.
In both the cases, please perform the steps below to delete the upper and lower filter values from the registry: Before performing the below steps, better take backup of the registry if something goes wrong, you can open the Backup file to restore the old registry values:
STEPS TO BACKUP THE REGISTRY
  1. Click the Start button, and then in the Search field, type regedit .
  2. Press the Enter key. NOTE: If prompted for an administrator password or a User Account Control prompt is displayed, type the appropriate password, click Continue or click Yes .
  3. In the Registry Editor window, on the menu bar , click File .
  4. In the File menu, click Export .
  5. In the Export Registry File window, under Export range , click the All radio button.
  6. In the File name box, enter the name for the exported file and then click the Save button.
  7. In the Registry Editor window, click the X button at the upper-right to close the Registry Editor.
STEPS TO DELETE UPPER AND LOWER FILTERS TO RESOLVE THE ISSUE WITH THE OPTICAL DRIVE
  1. Click the Start button, and then click Run .
  2. In the Run window, next to Open: , type: regedit .
  3. Press the Enter key.
  4. In the Registry Editor window, in the left pane , double-click the HKEY_LOCAL_MACHINE folder.
  5. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  6. In the System folder, double-click the CurrentControlSet folder.
  7. In the CurrentControlSet folder, double-click the Control folder.
  8. In the Control folder, double-click the Class folder.
  9. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  10. In the right pane , click to select the UpperFilters registry value.
  11. On the menu bar , click Edit .
  12. In the Edit menu, click Delete .
  13. In the Confirm Value Delete dialog box, click the Yes button.
  14. In the right pane , click to select the LowerFilters registry value.
  15. On the menu bar , click Edit .
  16. In the Edit menu, click Delete .
  17. In the Confirm Value Delete dialog box, click the Yes button.
NOTE: Do not delete the UpperFiltersBak orLowerFiltersBak registry values.
  1. Close the Registry Editor window.
  2. Restart the computer.
This will resolve the issue.
Thanks!!!!
Dec 30, 2010 | Computers & Internet
I have lost the dvd drive icon "E" in "my computer" it is telling me the driver is the latest but i cannot play a cd or dvd the laptop was given to me,
Do the following steps.
1) Click the WINDOWS START BUTTON
2) Click over the Windows START BUTTON, there is the SEARCH engine.
Click there and search for regedit
3) Click regedit and the Registry Editor folder will open
4) On the left menu, in order to make the folders drop down, click
the following folders with an arrow as follows:
HKEY_LOCAL_MACHINE, then,
SYSTEM, then,
Control, then,
Class, then look for {4D36E965-E325-11CE-BFC1-08002BE10318} "Be careful, you should choose this Registry"
5) On the right side of this folder, you will see some files (probably
with a small "ab" on a little paper which is an icon). Look for
LowerFilter and right-click it and DELETE IT. Yes, delete the file!
Don't worry if you think it could damage your computer system
since, HOPEFULLY, you have already created a Restore Point
for your system.
6) After deleting the LowerFilter file from your system,
RESTART your computer.
7) Look for the CD/DVD drive and it should be back to normal.
Wish it works.
Aug 11, 2010 | Acer Aspire 6920 Notebook PC
Usb hdd shows up in my computer but i cant access my files
In your windows computer, right click on this drive and click on Search. In the search window click on More Advanced Options and check the checkbox to "Show hidden files and folders" and in the Search field type *.* and click on Search button, all the contents of the drive would be shown there and you can check if the files come in search results or not? In case they do, right click on any file and select the option "Open Containing Folder" and the folder containing the files would open up.
Please rate this solution in case it works, in case it doesnot, please do not rate it and leave a comment and I shall help you further.
Aug 12, 2009 | Computers & Internet
APPLE MACBOOK WOULD BOOT. THE BOOT CD IS
unfortunately on the newer mac computer including the macbook you cannot boot to open firmware but there are other options
option 1)simply try holding down the mouse button or track pad button during boot after the first chime is sounded this will instruct the computer to eject the cd through the firmware
option 2) you can bypass the cd boot by holding down the option key after the first boot chime another simple solution this will allow you to choose a startup disk during...startup after which you can try the eject button on the keyboard or select the disk in finder and eject via trash can or eject symbol(symbol located in the open folder view of finder)
option 3) there is also a manual eject button though it may be harder to locate as they have change placements of it over the years however it can usually be found by probing the top center or far right of the cd slot with a paper clip just be gentle you don't want to damage an expensive piece of equipment by just carelessly jamming metal in it
you may want to try searching apple with your particular model and search for manual cd eject
best wishes, Crash
Apr 24, 2009 | Apple MacBook Mac Notebook
SanDisk Cruzer Micro 2.0GB not allowing me to erase files
your drive has become write protected for this file and folders.
run computer in safe mode , chances of recovery good in safe mode.
anaesarora online
Jan 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Lost cd for my printer-lexmark x2600
Hi denisel_houc, just click on the link below & scroll down the page to, "Lexmark X2600 - Drivers and Downloads".
Click on your operating system; http://search.lexmark.com/printer/US/en/12L1685
Or for windows XP click this link; http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:92:0:0
Click the download now button.
Create a folder on your desktop & name the folder.
Save the file, lc2600en.32.exe into the folder you created on your desktop. Once downloaded open the folder & double left click on the lc2600en.32.exe file. Follow any on screen instructions.
The file will uncompress & will install the Lexmark X2600 software.
Good luck denisel_houc!
Thank you for using fixya.
Mike
Dec 11, 2008 | Lexmark X2500 All-In-One Printer
Video playback problem on lumix dmc tz3
I don't have a solution to the first part of your dilemma (why it won't playback) but I do have a solution for deleting the file.  On your camera are "hidden" file folders.  When you connect your camera to your computer, you probably only see two folders (that's all I see for my DMC-LZ8).  But there are more, and your undeletable picture/video is in one of these folders.  Find the folder and you'll find the file.  Delete it from your camera using the computer to do the command.  Problem solved.  Okay, so how do you find the hidden folders?  I have a Mac, so my process was this:  1) Connect camera to computer; 2) Select/open camera icon (looks like "volume disk"); 3) From top Finder bar, select File then Find;  4) Select the camera volume to limit your search to the camera (not HD or other external hard drives you may have connected to your computer); 5) Select "Kind" and in the next dropdown button "Folders".  Voila.  Happy searching.  My hidden "undeletable" video files were in a folder called "100_PANA".  I selected them then moved them to the Trash.  Be sure to eject your camera properly (don't just turn it off or disconnect it).
Good luck.  I hope this helps.
PS - My theory is that this occurred after an upload to my computer got unexpectedly disconnected before everything finished loading or else the camera got disconnected from the computer incorrectly even if the upload had already finished (see above comment to eject camera properly).  In either case, the blank/black screen, unviewable but "there" on the camera taking up memory photos/videos problem happened to me, too.  The above actions resolved it for me.
Apr 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Dead Driver for Easy CD Creator
Resolution WARNING: THIS PROCEDURE MIGHT CAUSE ANY OTHER ROXIO OR ADAPTEC SOFTWARE INSTALLED ON THE PC TO BECOME INOPERABLE. PLEASE UNINSTALL ANY OTHER ROXIO OR ADAPTEC SOFTWARE FIRST BEFORE ATTEMPTING THE LISTED PROCEDURE.
  1. Renaming the Take Two system file
    • Click on the Start button, and then select Search
    • Search your Local Hard Disks for the following file prtseqrd.sys
    • If you do not find this file, please go to step 2
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. prtseqrd.sys would be renamed to prtseqrd.rox)
      NOTE: If you decided to not finish this article at any point please rename this file back, you will be doing that later in this article. right hand corner of the window
  2. Remove Easy CD Creator 5 from Add/Remove Programs
    • Click on the Start button, then go to Setting and select the Control Panel
    • Double click on the Add/Remove Programs icon
    • Uninstall Adaptec Easy CD Creator 5, if prompted choose No to reboot the PC
    • Then click the X in the top right hand corner of the Window to close the control panel
  3. Removing Directories from your Hard Drive
    NOTE: All directories stated might not be found
    • Click on the Start button, then right click on the My Computer icon and then select Open
    • Double click on the icon for the Local Disk that the software was installed to
    • Double click on the Program Files folder
    • Locate the Roxio and Adaptec folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common Files folder, locate the Roxio Shared and Adaptec Shared folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common File\\InstallShield folder, locate the Engine and Iscript folders and rename them to Engine.ROX and Iscript.ROX. Once all the directories are remove right click on the "X" in the top right hand corner of the window to close it
  4. Rename additional files on your hard drive
    NOTE: All files in the list might not be found
    • Search your Local Hard Disks for the following files:
      *CDR4_2k.sys
      *CDR4_XP.sys
      *Cdr4dll.dll
      *Cdr4vsd.sys
      *Cdr4vsd.vxd
      *Cdral.dll
      *CDRALw2k.sys
      *Cdrtc.dll
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. cdrtc.dll would be renamed to cdrtc.rox)
    • After all files are searched for and renamed close the search window by clicking on the "X" in the top right hand corner of the window
    WARNING: THE NEXT STEPS INVOLVES EDITING YOUR SYSTEM REGISTRY. WE STRONGLY RECOMMEND YOU EXPORT YOUR REGISTRY BEFORE SYSTEM DAMAGE. WE RECOMMEND THAT IF YOU DO NOT FEEL COMFORTABLE EDITING YOUR REGISTRY THAT YOU SKIP THESE STEPS.
  5. To export a copy of your registry, please do the following:
    • Click on the Start button, then select Run
    • Type regedit and click the OK button
    • Locate and left click FILE in the upper left hand corner of the Registry Editor, then click on Export
    • Choose the Desktop as the location to save the file in, and name the file regbackup
    • Also ensure that under the Export Range section there is a dot beside All
    • Click on the Save button. Your registry should now be backed up to a file named regbackup.reg on your desktop.
  6. Remove the Roxio and Adaptec registry entries
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the + next to it.)
    • Expand the SOFTWARE Key
    • Locate the Roxio and Adaptec folders, right click each folder and click on Delete
    • If prompted to confirm the delete click the Yes button
    • Collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Expand the HKEY_CURRENT_USER key
    • Expand the SOFTWARE key
    • Locate the Roxio and Adaptec folders, right click on each folder and click on Delete
  7. Remove the UpperFilters and LowerFilters values:
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
    • Expand the SYSTEM Key
    • Expand the CurrentControlSet Key
    • Expand the Control Key
    • Expand the Class Key
    • Please look for a key containing the following string of letter and numbers: {4D36E965-E325-11CE-BFC1-08002BE10318}
    • High light this key by left clicking once on it
    • On the right hand side you are looking for UpperFilters and LowerFilters under the Name column, once you find these please delete them by right clicking on them and choosing delete
      Note: It will be easier to use the Registry editor in the future if you collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Please exit the registry by clicking on the "X"in the top right hand corner of the screen
  8. Renaming the Take Two system file
    • Search your Local Hard Disks for the following file prtseqrd.rox
    • If found, right click on the file and then click on rename. Change the file extension to SYS (i.e. prtseqrd.rox would be renamed to prtseqrd.sys)
  9. Shut down and Reboot the PC
    • Click on the Start button, then click on Shut Down
    • Choose the Restart option and click the OK button
    • Adaptec Easy CD Creator 5 should now be removed from your PC
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
Microsoft HP Pavilion DV6276US Notebook PC Logo
99 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
