Question about Music
Need ohms out put for sears silvertone 1465 guitar amp
Ss amp from 1966
3 Suggested Answers
PolyrhythmFX
  • 109 Answers
SOURCE: I need guitar schematics for a silvertone by Samic
Go here: http://www.seymourduncan.com/support/wiring-diagrams/
Select you pickup/controls/switch configuration and it will show the corresponding wiring diagram.
Posted on Jun 20, 2009
  • 979 Answers
SOURCE: Fuse - 2amp for a Silvertone 1472 Amplifier
Hello endaya try www.digikey.com if you are using a 2amp buss fuse, its available, 117V is applicable to 220V, just follow the amp rating.
Posted on Apr 22, 2010
Testimonial: "Thanks! Information provided was very helpful. Much appreciated!"
I hav a Silvertone sslb11 bass that needs a new volume pot and don't know wich one to buy. I don't see any part numbers or values printed on the pot. Does anyone know part numbers, brand, or...
I recommend checking music stores in your area for that, it doesn't have to be any specific rating of impedence. Depending on brand, I see guitars with anything from 50 ohms to 250 ohms. This only allows a faster cutoff on volume than others. The most critical action is to have a smooth taper, meaning a straight volume rise or decline versus one that goes down slowly or quickly and suddenly cuts off. Most any guitar volume control from a music store will work just fine. In case I confused you, ohms is the rating of the control, the taper or smoothness is classed as A, B, or C. A is normally for volume controls and B is used mostly for tone controls. Knowing that should give you insight insight to the difference of the controls.
Mar 31, 2013 | Music
The input cable fits into the guitar but it won't stay put, it just slides out as if it were too small.
Pro's loop the cable through their belt or guitar strap to avoid cable pulling out or twisting and wearing the connector.
Aug 02, 2011 | Silvertone Revolver - SS11 Electric Guitar...
Why dose my guitar amp make a high pitch sound when i turn it on
If you have an instrument plugged into the amp, then you need to turn down the volume of the amp before turning on the amp. Otherwise you risk permanent damage to your speaker. Also, the instrument cord may be defective. The hot and ground wires may be shorted together. You need an ohm meter to test your cord. With the cord unplugged and detached, put the positive (red) lead of the ohm meter on the tip of the plug and the negative (black) lead on the sleeve of the plug. You should not have any reading at all. If you get a reading then you have a bad cord with a short.
Aug 01, 2010 | Marshall 15 Watt Guitar Amp
I need to know the ohm rating for the speaker in a
usually combo amps are 8 ohm for guitar. a 16 ohm speaker load comes into play usually on half stack set ups. danville tec 10d, i would guess a ten inch speaker, which is also very common for guitar amps.
May 15, 2010 | Peavey Pv 2600 Power Amplifier
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I need a vibrato bridge for a silvertone 1480
Try this website:http://www.rareguitarparts.com/ Hope this helps.
Mar 28, 2010 | Ibanez AF75TDGIV AF Series Electric Guitar...
Judging from the "10D", that most likely means 10 watts. 6.5 inch speaker, probably 8 ohms. Most amps of this nature have 8-Ohm speakers.
Their 12-watt and 15 watt amp have a 6.5". Their 20 watt amp has an 8". The 80 watt has a 12".
Hope this helps.
Mar 28, 2010 | Peavey Pv 2600 Power Amplifier
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
