Question about Vehicle Parts & Accessories
Where is the fuel gauge fuse on 99 magna - Vehicle Parts & Accessories
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 47 Answers
It should be under the dash and it's the fuse for your cluster and interior accessories
Posted on May 17, 2013
Why isn't the fuel gauge working on our chrysler voyager 1997?
On a car of that vintage, it might POSSIBLY be the ground wire, for the fuel tank level sending unit, inside the fuel tank. That requires a major procedure, by KNOWLEDGEABLE technicians who deal with this on a daily basis. Any other way is DANGEROUS AND WILL BE FATAL.
Jul 04, 2014 | Delphi Fuel Pump Chrysler Town & Country...
What caused my 99 Honda Magna to die while running great at 45 mph?
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
85 Magna v65 dies is dying while riding and won start up till cool
http://www.motorcycleforum.com/59-motorcycle-repair/100103-please-help-bike-died-out-while-riding.html
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Jul 02, 2014 | 1999 Honda VF 750 C Magna
1983 Honda VF 1100 C low fuel light not working
Hi, John and the usual suspects are:
1. Blown instrument fuse.
2. Faulty sending unit.
3. Faulty wiring between sending unit and gauge.
4. Faulty ground or power connection.
5. Blown indicator light.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1984 Magna Low fuel sensor
Honda Magna low fuel sensor repair
Honda V65 MAGNA Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Mar 15, 2013 | 1983 Honda VF 1100 C
99 ram 1500 truck fuel gauge stopped working
Faulty sending unit.If fuse was bad the pump would not come on.
Feb 04, 2012 | Cars & Trucks
I need to locate the fuse for my gas gauge in my 99 malibu
There is no fuse specific to the fuel gauge. The Instrument panel has two fuses that supply power to everything it has on it. The fuel gauge signal is received from the body control module which sends out a signal voltage to the fuel level sending unit. Depending on where the float in the tank in determines how much resistance the sending unit has. the body control module interprets the voltage value into a fuel level and sends a signal to the gauge.
If the gauge is not working the most common cause is the sending unit in the tank.
Nov 11, 2010 | 1999 Chevrolet Malibu
99 4runner Fuel Gauge has inaccurate reading
Disconnect and reconnect gauge or you can install an external fuel gauge. You can try checking for blown fuse or ground connection.
Jun 10, 2017 | Toyota 4Runner Cars & Trucks
99 navigator gas gauge doesnt work all of a
some are on a fuse link but most of them have the fuel pump and gauge sender on the pump, it has a wire winding to work the gauge msounds like the whole fuel pump gauge sender needs to be replaced, thanks robert b.
Jun 19, 2009 | 1999 Lincoln Navigator
Fuel pump not working in a Mitsubishi Magna 3.0 wagon
wer is the fuel pump situated in the back of my 94 magna advance wagon plz
Jun 02, 2009 | 1995 Mitsubishi Diamante
My gauges (speedo,tach
the display is going out and will have to be replaced.with new or reman.
Feb 20, 2009 | 1998 Lexus Gs 400
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
