Question about Toshiba COPIERS E-STUDIO 600 Copier
I chenged the hdd on toshiba e-studio 600 after pressing 3+clear, and 3 and start botton, appears on the lcd please set correct usb storage device, what this mean??
2 Suggested Answers
  • 653 Answers
SOURCE: my company have 2 unit
CD30 shows that the waste toner on the recycle unit is full. U need to dispose it. Open the front cover, take out toner drive, take out the 2 covers, and u will see the recycle unit.
Posted on May 31, 2011
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Toshiba estudio 282 code F100
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
Feb 25, 2013 | Toshiba e-STUDIO 282 Black and White...
Can not read HDD data in toshiba e-studio 600
Ah, a common one. Here goes Juan.
You've already replaced the drive and gone with the 3-C Power on option 3. What you'll have to do now is get your hands on the firmware. For the 850 series (the 600 is part of that series) I believe it is SYS 356. You may have to get ahold of a certified Toshiba dealer to get your hands on that firmware. Good thing is it's easy once you've got it.
Put it on a thumbdrive (1 GB or smaller), insert it on the right rear of the machine, hold down 4-9 power on and you'll be in firmware update mode.
Just in case I'm wrong about the version, keep an eye out for the NIC firmware to be selected. If it is, unselect it, it will FRY that NIC card, trust me.
Feb 12, 2013 | Toshiba COPIERS E-STUDIO 600 Copier
Whenever i try to connect my mobile to pc studio through usb cable its not connected why?
please check the usb port of PC secondly when u connect to pc some command appears on mobile press pc studio mode . and more tell me which set u wants to connect as some phones setting has to changed in setting menu of phone like mass storage or pc studio mode
Dec 12, 2010 | Cell Phones
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Dec 03, 2009 | Toshiba e-STUDIO 282 Black and White...
What steps to take after installing a hard drive on a toshiba 350
button.
Nov 26, 2008 | Toshiba e-Studio 350 Copier
Problems with Toshiba copier
Just press these keys with sequence and with in 2 or 3 seconds .first press clear,then auto photo mode select key,again clear ,auto photo key,.copier will go dead .now press 14 then start key.problem will bi removed.
clear key,auto photo key,clear,auto photo key,
when display dead 14 start key.
BY MIAN JEE
Nov 15, 2008 | Toshiba e-Studio 350 Copier
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
