Question about Car Audio & Video
I have a single 15" sub woofer in a box it was
    Problem Solver:
  • 10 Answers
Simply put, burned voice coil. Either too much power can do this or not enough power with distortion. solution- if the sound is clear then its too much power- turn the amp down. If the sound is distorted and raspy- its not enough power and your getting distortion-get bigger amp.
Posted on Jan 16, 2013
  • 214 Answers
SOURCE: smoking
Sounds like you have burnt out something (as you probably already know LOL) but maybe you just over heated some wires that couldn't take the Amperage. If this is the case, you MUST find out:
Why there was so much Amperage there at the time
Why didn't the Fuse blow? (perhaps too high an Amperage fuse for the Unit?) and
Why could your unit not handle the Power? (perhaps not Rated for that Power Output?).
Note: Watts and Amperage are not Musical terms, they are Electrical terms. So an Amplifier Increases the output Current to a maximum level designated in various ways as PMP (common but misleading) RMS (the International Standard) and DIN (the mainly European standard). The receiving unit (in this case your sub woofer is designed to handle a maximum level of Current input and this is usually desribed (again misleadingly) as simply Wattage. The common factor here is that both your Amplifier and Sub woofer are probably using the PMP rating.
If this is the case then you can easily determine if the 2 units are compatible using their "Wattages". For instance, a 275 Watt amplifier is too much at HIGH outputs (volume) for a set of speakers Rated at 160 Watts (they will "blow") but will work fine at Lower volumes because the Amp is putting out less Power at Lower volumes and is therefore probably below the Speakers Maximum input range.
Conversely, it is OK if the speakers are Rated for higher inputs than your Amplifier can put out. For example, a 175 Watt amplifier is fine with speakers Rated for 240 Watts because it can never produce enough power to "blow" the speakers.
Just putting in heavier wires will almost certainly bow up the sub woofer if the initial problem is not solved.
Take it to a HI FI shop and get them to look at it. If they simply say "Can't repair these, buy this one", try another shop.
Sorry about the lecture.
Good luck.
Posted on Apr 13, 2008
  • 74 Answers
SOURCE: box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Posted on Feb 17, 2009
  • 19 Answers
SOURCE: alpine sub woofer
your speakers are hooked up wrong. hook both positives together and both negatives together and bridge it to the amp. if it is one channel hook it up as one together. if it is 2 channel hook positive to one side and negative to the other side.
Posted on May 19, 2009
  • 13 Answers
SOURCE: 2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
Posted on Jul 19, 2009
herbalgarden
  • 344 Answers
SOURCE: locked up sub-woofer cone won't move?
In theory your idea would work, however you risk damaging your amp by reversing polarity and the positive and negative wires from your head unit are low voltage so they wont provide enough current in reverse or normal polarity to free the cone of your sub. but here is something that you can try that is similar in concept.
Take a positive lead from your head unit and wire it to the negative of your sub. Now ground the positive terminal of your sub to the vehicles chassy using a wire. This creates a 12v-14v reversed polarity current that should be strong enough to (POP) the cone so to speak. hope this helps
Posted on Sep 27, 2009
Testimonial: "thnxx should work ttyl "
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
Tip
Box specs and airspace for 8 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
on May 29, 2011 | Car Audio & Video
Tip
Box specs and airpsace for 12 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 27 liters, meaning that you will end up with a box of 13 inches high, x 13 inches wide, x 13 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
Can i power 2 12 subs a rockford punch z and a xplode with this amp i found all this **** in my garage and i need to know if it will power all this
First of all. Using two different kinds of sub woofers, is not an option, as these two sub woofers have different specifications and you should never mix sub woofers. Now the better choice from the 2, would probably be the Rockford. (cant be sure without knowing the models, power handling is also a factor in how well either of the sub woofers will play, but Rockford as a rule makes better sub woofers than Sony does) In my opinion, both the sub woofers deserve a better amplifier than what Boss has to offer. However to connect either of these sub woofers, you would need to determine how many voice coils it has and how many OHM the voice coil/s are. If it is a DVC (dual voice coil) and each voice coil is 4 OHM or 2 OHM, then you can connect one voice coil to one channel of the amplifier and the other voice coil to the other channel of the amplifier. If it is a DVC 2OHM you can also connect it wired in Series/Series to give a 4OHM load and should be connected to the BRIDGE dedicated speaker outputs of your amplifier. If it is a SVC (single voice coil) and it is 4 OHM, then you can connect the sub woofer to the designated speaker outputs of your amplifier that states BRIDGE. DO NOT run the amplifier in BRIDGE mode at 2 OHM as this will probably damage the amplifier. dreamsystems
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
Tip
Box size and airspace for 10 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 10 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 26 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. <br />Enjoy! <br />
Some weeks ago the sub stopped working. Thought dog had chewed the coaxial driver cable, but not shorted (now). Tried another sub w/o success.
Hi, I went to the Denon website and they have no documentation there for your receiver.
But do not frown, I have some good suggestions for you.
0 Don't beat the dog. After all, it's their job to chew things.
1 Get a new, un-chewed cable and see what happens between the sub output and the sub woofer. If it works, your in business. If it does not work. Don't be discouraged . Go to step #2
2 If the sub output on the Denon has failed, and everything else is good. There is another way to use your sub.
Install a patch system using the Headphone output from the front of the Denon. It may seem odd, but it works exceptionally well for the following reasons. It works on all signal sources. So if you are not playing a home theater source, you still have the use of your sub.
You will need the following adapters.
1 A Male stereo phone jack to female mini-phone jack. (Something that would accept typical small headphone sets such as those on an iphone).
2 A stereo "Y" connector that that has a single stereo male mini-phone jack that has two "RCA" female jacks.
3 A simple RCA male to male stereo cable pair as is commonly used to connect CD players, etc. i.e. separate red and white RCA connectors at both ends.
1 and 2 above may be available as a single unit combined with each other.
Take these adapters and connect the Item 1 into the Receiver, Item 2 plugged into Item 1, Item 3 plugged into Item 2 and finally the other end of Item 3 plugged into the two female RCA jacks mounted onto the back of the sub-woofer. If the sub only has one female RCA connector, get a RCA "Y" connector that has a single male end to 2 female ends.
This setup will work perfectly with any sub. The reason is as follows. Most decent subs have an adjustable high frequency cut off. So you can vary it from about 20Hz up to about 140 Hz.
I recommend that it is cut off at 80 hz. This way the bass transition is usually seamless between the woofer and the rest of the system. .
Then adjust the woofer volume control in a similar manner.
If it all works out, give the dog a treat and enjoy yourself.
I really hope this helps, I love my sub woofer as well.
Let me know how this turns out.
If you have any questions please post them on the site and I'll get back to you ASAP.
Best Regards,
Mark
Jan 22, 2011 | Denon AVR-3600
Sub woofer output port does not seem to work on my kenwood VR 407, checked sub woofer on another system - works fine, any easy solutions?
Is the 407 set up to drive the unknown sub. It's not just plug n play.
The manual will guide you, around page 15. Also refer to your subwoofer manual. Try retrevo.com for that one.
http://www.retrevo.com/support/Kenwood-VR-407-Receivers-manual/id/480ag200/t/2/
Dec 29, 2010 | Kenwood VR-407 Receiver
15PLB76 15 Inch 800 Watt Woofer Car Speaker: what subs will be good to fit in my gmc sierra sin...
single shallow with a sealed box it would sound great!! no air tombs they **** thats called ported they really ****
May 17, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Just stopped playing
is it a seald box or a ported box?
Oct 23, 2007 | Jl Audio 12W7 Car Subwoofer
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
