Question about Sony Cyber-Shot DSC-P52 Digital Camera
Turn of and try again
My camera shows the pics i already have on there and all that and does everything.
and where the lens is it goes in and out in and out. and then says turn of and try again. but it does everything eles
please tell me the answer asap
  • 139 Answers
You camera goes in a stand by mode you need to use a memory card nothing is wrong with the camera. So I would suggest you must use a memory card reader for this purpose.
Posted on Jan 20, 2009
My camera cant take a pic it has f -- show on monitor and it show R 11 what should i do ?
Is this a Nikon digital? If so:
"F--" means there is either no lens attached or there is a non cpu lens attached. The "Rxx) is the estimated number of images that may be taken with the present media card.
For the lens: TUrn camera off, remove lens and carefully clean the cpu contacts on lens mount and lens itself with a cotton swab lightly dampened with pure water. DO NOT OVER WET THE CAMERA OR LENS. LEt dry thoroughly, replace lens and try again. Try manual mode. If there is a camera hardware reset buttion, try that....Good Luck!
Nov 14, 2010 | Cameras
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Was taking pics & everything was okay. put the battery on the charger & when I put it back in the camera a while later the camera turned on, went right off then i hit power on again & it turned...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
May 06, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
I have a Canon IXUS 8015 digital camera with the lens stuck out. I've tried everything I've read on websites to fix it, from pushing the lens in, lightly banging the side where the USB goes in, battery in...
i too have had this problem,i sent it to be repaired and 4 months later it came back,then 2 days later it don eit again,so i took it apart,then i happened to have a compressor then blue everything out ,turnin it of and on until i tworked then blow every piece as u piece it back together,i stripped it as far as i could,now it breaks down lik e all the time,so i jus take it apart,ps when u turn it on or off ALWAYS have the lense facing the floor,this will help,actually i have a new problem with mine ,it takes pics but only on sum settings it wont allow me to see the pic on the screen as i take it,but it does actually take it,i tell u what i am sure off,cannon new this camera was shagged when they released it,my opinion they should give everyone double there money back for there stupidity
Jan 05, 2010 | Canon IXUS 80 IS Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Sony Cyber-shot DSC-W55...
Dear Julie339
Battery of your camera has less charge storage/ got weak.
Replace with new battery and try it. Hope problem would be solved.
May 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Camera wont stay on, please help
Possible that the Lens Mechanism is out of sync. If its still within warranty just bring it in and have it serviced. If not I may be able to help you out but it requires dismantling the camera,..
If any one knows a quicker and easier way maybe they can post it here But as far as experience goes thats what happened with mine,
Hope this helps
Oct 12, 2007 | Casio Exilim Card EX-S600 Digital Camera
HP R707 Digi Cam...zoom lense not working
I had the same problem - try to wiggle the zoom lense really carefully and the switch it on again. The zoom objective is canted a little bit and the motor is too weak to move the zoom objective. You can also open the camera by removing all 8 screws around the camera and then removing the metal front (Just pull it in the direction of the zoom lens with your fingernails). Then you can access the zoom lens better ... Andy
Sep 05, 2007 | HP Photosmart R707 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
